Datasheet MA12070 (Infineon) - 5
ManufacturerInfineon
Description2x80W ultra power efficient, fully integrated audio amplifier IC with analog input
Pages / Page86 / 5 — Table 4-1. Pin No. Name. Type1. Description. www.infineon.com
Revision01_00
Table 4-1 Pin No Name Type1 Description www.infineon.com
4.2 Pin Function
Table 4-1 Pin No. Name Type1 Description 1
PVSS P Power ground for internal power amplifiers
2
3
CF0AN P Connect to external flying capacitor negative terminal for amplifier channel 0A
4
OUT0A O Audio power output 0A
5
6
CF0AP P Connect to external flying capacitor positive terminal for amplifier channel 0A
7
PVDD P Power supply for internal power amplifiers
8
9
CF0BP P Connect to external flying capacitor positive terminal for amplifier channel 0B
10
OUT0B O Audio power output 0B
11
12
CF0BN P Connect to external flying capacitor negative terminal for amplifier channel 0B
13
14
15
/CLIP O Audio clipping indicator (open drain output), pulled low when clipping occurs
16
/ERROR O Error indicator (open drain output), pulled low when an error occurs
17
AVDD P Power supply for internal analog circuitry
18
CMSE O Decoupling pin for internally generated common-mode voltage in SE configuration. Should be externally decoupled to AVSS. Can be left floating for 2 x BTL and PBTL configurations.
19
AVSS P Ground for internal analog circuitry
20
CREF O Decoupling pin for internally generated analog reference voltage. Should be externally decoupled to AVSS.
21
IN0A I Analog audio input 0A
22
IN0B I Analog audio input 0B
23
IN1A I Analog audio input 1A
24
IN1B I Analog audio input 1B
25
26
DVSS P Ground for internal digital circuitry
27
SCL IO I2C bus serial clock
28
AD0 I I2C device address select 0 (see “MCU/Serial control interface” section)
29
AD1 I I2C device address select 1 (see “MCU/Serial control interface” section)
30
SDA IO I2C bus serial data
31
CLKM/S I Clock master/slave mode select. When pulled low the device is in clock slave mode. When pulled high the device is in master mode.
32
CLKIO IO Clock input when in clock slave mode (CLKM/S is pulled low) or clock output when in master mode (CLKM/S is pulled high)
33
/ENABLE I When pulled high, the device is reset and kept in an inactive state with minimum power consumption.
34
/MUTE I Mute audio output when pulled low
35
36
37
CF1BN P Connect to external flying capacitor negative terminal for amplifier channel 1B
38
OUT1B O Audio power output 1B Datasheet Please read the Important Notice and Warnings at the end of this document V 1.0
www.infineon.com
page 5 of 86 2018-07-17
