Datasheet STSPIN32F0B (STMicroelectronics) - 8
DescriptionAdvanced single shunt BLDC controller with embedded STM32 MCU
Pages / Page36 / 8 — STSPIN32F0B. Electrical characteristics. Symbol. Parameter. Test …
File Format / SizePDF / 6.5 Mb
STSPIN32F0B. Electrical characteristics. Symbol. Parameter. Test condition. Min. Typ. Max. Unit. DS12907. Rev 1. page 8/36
STSPIN32F0B Electrical characteristics Symbol Parameter Test condition Min Typ Max Unit DS12907 Rev 1 page 8/36
link to page 9 link to page 9 link to page 9
STSPIN32F0B Electrical characteristics Symbol Parameter Test condition Min. Typ. Max. Unit
Open loop, VDDA floating fSW Maximum SW switching frequency - 200 330 kHz ISW = 100 mA RSWDS(ON) Switch ON resistance ISW = 200 mA - 1.4 - Ω η Efficiency VM = 8 V; IDDA = IDDA,max - 80 - % ISW,peak Peak current threshold - - 320 - mA IOVC Latched overcurrent threshold - - 1 - A tSS Soft-start time - 2.5 5 7.5 ms Linear regulator VM = 13 ÷ 45 V (3) V Linear regulator output and gate driver supply REG12 11.4 12 12.6 V voltage IO = 10 mA VREG12,drop Drop voltage VM = 8 ÷ 11 V, IO = 10 mA - 200 400 mV IREG12,lim Linear regulator current limit VM = 13 V 20 - 40 mA Gate drivers ISI TJ = 25 °C 400 600 - mA Maximum sink/source current capabilities ISO Full temperature range 350 - - mA RPDin Input lines pull-down resistor - 30 60 95 kΩ ton Input-to-output propagation delay (4) - - 20 40 ns toff MT Delay matching, HS and LS turn-on/off (5) - - 10 20 ns RDS_diode Bootstrap diode ON resistance - - 120 240 Ω Operational amplifier Vicm Input common mode voltage range - -0.1 - VDD + 0.1 V Vout = 1.65; Tj = 25 °C - 1 6 mV VOPio Input offset voltage Vout = 1.65; full temp. range - - 7 mV IOPio Input offset current Vout = 1.65 - - 100 pA IOPib Input bias current - - 100 pA CMRR Common mode rejection ratio 0 to 3.3 V; Vout = 1.65 V 70 90 - dB AOL Open loop gain RL = 10 kΩ; Vout = 1.65 - 90 - dB VDD - VOH High level output voltage RL = 10 kΩ - 15 40 mV VOL Low level output voltage RL = 10 kΩ - 15 40 mV Vout = 3.3 V; Tj = 25 °C 18 - - mA Sink output current Vout = 3.3 V; full temp. range 16 - - IOUT Vout = 0 V; Tj = 25 °C 18 - - mA Source output current Vout = 0 V; full temp. range 16 - - RL = 2 kΩ; CL = 100 pF GBP Gain bandwidth product 10 18 - MHz Vout = 1.65 Phase margin = 45° Gain Minimum gain for stability - 4 - V/V 0.2 V < Vout < VDD - 0.2
DS12907
Rev 1 page 8/36
Document Outline 1 Description 2 Block diagrams 3 Electrical data 3.1 Absolute maximum ratings 3.2 ESD protections 3.3 Recommended operating conditions 3.4 Thermal data 4 Electrical characteristics 5 Pin description 6 Device description 6.1 UVLO and thermal protections 6.1.1 UVLO on supply voltages 6.1.2 Thermal protection 6.2 DC/DC buck regulator 6.2.1 External optional 3.3 V supply voltage 6.3 Linear regulator 6.4 Standby mode 6.5 Gate drivers 6.6 Microcontroller unit 6.6.1 Memories and boot mode 6.6.2 Power management 6.6.3 High-speed external clock source 6.6.4 Advanced-control timer (TIM1) 6.7 Test mode 6.8 Operational amplifier 6.9 Comparator 6.10 ESD protection strategy 7 Application example 8 Package information 8.1 VFQFPN48 7 x 7 package information Revision history Contents List of tables List of figures
