Datasheet ADuM4137 (Analog Devices) - 2
DescriptionHigh Voltage, Isolated IGBT Gate Driver with Fault Detection
Pages / Page28 / 2 — ADuM4137. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 2/2019—Revision …
File Format / SizePDF / 673 Kb
ADuM4137. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 2/2019—Revision 0: Initial Version
ADuM4137 Data Sheet TABLE OF CONTENTS REVISION HISTORY 2/2019—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 4 link to page 4 link to page 8 link to page 8 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11 link to page 13 link to page 14 link to page 15 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 18 link to page 19 link to page 19 link to page 20 link to page 26 link to page 26 link to page 27 link to page 28 link to page 28 link to page 28
Features .. 1 Theory of Operation .. 15 Applications ... 1 Applications Information .. 16 General Description ... 1 PCB Layout ... 16 Revision History ... 2 SPI and EEPROM Operation.. 16 Functional Block Diagram .. 3 User Register Map .. 17 Specifications ... 4 User Register Bits ... 17 Electrical Characteristics ... 4 Configuration Register Bits... 17 SPI Timing Specifications ... 8 Control Register Bits .. 18 Package Characteristics ... 8 SPI Safety ... 19 Regulatory Information ... 9 Propagation Delay Related Parameters ... 19 Insulation and Safety Related Specifications .. 9 Protection Features .. 20 DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Insulation Lifetime ... 26 Characteristics .. 10 DC Correctness and Magnetic Field Immunity... 26 Recommended Operating Conditions .. 10 Typical Application Circuit ... 27 Absolute Maximum Ratings .. 11 Outline Dimensions ... 28 Thermal Resistance .. 11 Ordering Guide .. 28 ESD Caution .. 11 Automotive Products ... 28 Pin Configuration and Function Descriptions ... 13 Typical Performance Characteristics ... 14
Rev. 0 | Page 2 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ELECTRICAL CHARACTERISTICS SPI TIMING SPECIFICATIONS SPI Timing Diagram PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PCB LAYOUT SPI AND EEPROM OPERATION SPI Programming USER REGISTER MAP USER REGISTER BITS OFFSET_2[5:0] Bits GAIN_2[5:0] Bits OFFSET_1[5:0] Bits GAIN_1[5:0] Bits CONFIGURATION REGISTER BITS OT_FAULT_OP Bit OT_FAULT_SEL Bit OC_TIME_OP Bit OC_2LEV_OP Bit LOW_T_OP Bit OC_BLANK_OP Bit tBLANK[3:0] Bits ECC_OFF_OP Bit T_RAMP_OP Bit PWM_OSC CONTROL REGISTER BITS ECC2_DBL_ERR Bit ECC2_SNG_ERR Bit ECC1_DBL_ERR Bit ECC1_SNG_ERR Bit PROG_BUSY Bit SIM_TRIM Bit SPI SAFETY PROPAGATION DELAY RELATED PARAMETERS PROTECTION FEATURES Primary Side UVLO Fault Reporting Overcurrent Detection High Speed, Two-Level Turn Off Miller Clamp Thermal Shutdown ASC Pin Functionality Isolated Temperature Sensor Low Temperature Operation Mode FAULTB Pin DRIVER_FAULTB Pin UVLO_FAULTB Pin VDD2 UVLO Fault UVLO_FAULTB Fault, Gate Low Dead Time Control DRIVER_FAULTB Fault, Dead Time Fault Power Dissipation INSULATION LIFETIME DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY TYPICAL APPLICATION CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
