Datasheet ADuM4136 (Analog Devices) - 7
DescriptionSingle-/Dual-Supply, High Voltage Isolated IGBT Gate Driver
Pages / Page16 / 7 — Data Sheet. ADuM4136. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VI+ 1. …
File Format / SizePDF / 663 Kb
Data Sheet. ADuM4136. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VI+ 1. 16 GND2. VI– 2. 15 VSS2. VDD1 3. 14 DESAT. VSS1 4. 13 VDD2
Data Sheet ADuM4136 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VI+ 1 16 GND2 VI– 2 15 VSS2 VDD1 3 14 DESAT VSS1 4 13 VDD2
Data Sheet ADuM4136 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VI+ 1 16 GND2 VI– 2 15 VSS2 VDD1 3 14 DESAT ADuM4136 VSS1 4 13 VDD2 TOP VIEW RESET 5 (Not to Scale) 12 VDD2 FAULT 6 11 VOUT READY 7 10 VSS2
3 00
V
5-
SS1 8 9 VSS2
57 13 Figure 3. Pin Configuration
Table 10. Pin Function Descriptions Pin No. Mnemonic Description
1 VI+ Positive Logic CMOS Input Drive Signal. 2 VI− Negative Logic CMOS Input Drive Signal. 3 VDD1 Input Supply Voltage on Primary Side, 2.5 V to 6 V. The supply that is connected to this pin must be referenced to VSS1. 4 VSS1 Ground Reference for Primary Side. 5 RESET CMOS Input. When a fault exists, bring this pin low to clear the fault. RESET has an internal 300 kΩ pull-down resistor. 6 FAULT Open-Drain Logic Output. Connect this pin to a pull-up resistor to read the signal. A low state on this pin indicates when a desaturation fault has occurred. The presence of a fault condition precludes the gate drive output from going high. 7 READY Open-Drain Logic Output. Connect this pin to a pull-up resistor to read the signal. A high state on this pin indicates that the device is functional and ready to operate as a gate driver. If READY is low, the gate drive output is precluded from going high. 8 VSS1 Ground Reference for Primary Side. 9 VSS2 Negative Supply for Secondary Side, −15 V to 0 V. The supply that is connected to this pin must be referenced to GND2. 10 VSS2 Negative Supply for Secondary Side, −15 V to 0 V. The supply that is connected to this pin must be referenced to GND2. 11 VOUT Gate Drive Output Current Path for the Device. 12 VDD2 Secondary Side Input Supply Voltage, 12 V to 35 V. The supply that is connected to this pin must be referenced to GND2. 13 VDD2 Secondary Side Input Supply Voltage, 12 V to 35 V. The supply that is connected to this pin must be referenced to GND2. 14 DESAT Detection of Desaturation Condition. Connect this pin to an external current source or a pull-up resistor. A fault on this pin asserts a fault on the FAULT pin on the primary side. Until the fault is cleared on the primary side, the gate drive is suspended. During a fault condition, a smaller turn-off FET slowly brings the gate voltage down. 15 VSS2 Negative Supply for Secondary Side, −15 V to 0 V. The supply that is connected to this pin must be referenced to GND2. 16 GND2 Ground Reference for Secondary Side. Connect this pin to the emitter of the IGBT or the source of the MOSFET being driven. Rev. 0 | Page 7 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performanace Characteristics Applications Information PCB Layout Propagation Delay Related Parameters Protection Features Fault Reporting Desaturation Detection Thermal Shutdown Undervoltage Lockout (UVLO) Faults READY Pin Pin Pin VI+ and VI− Operation Gate Resistance Selection Power Dissipation DC Correctness and Magnetic Field Immunity Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Typical Application Outline Dimensions Ordering Guide
