Datasheet ADUM3123 (Analog Devices) - 4
DescriptionIsolated Precision Gate Driver, 4 A Output
Pages / Page15 / 4 — ADuM3123. Data Sheet. Parameter. Symbol Min. Typ. Max. Unit. Test …
File Format / SizePDF / 493 Kb
ADuM3123. Data Sheet. Parameter. Symbol Min. Typ. Max. Unit. Test Conditions/Comments
ADuM3123 Data Sheet Parameter Symbol Min Typ Max Unit Test Conditions/Comments
link to page 12 link to page 8 link to page 12 link to page 12
SWITCHING SPECIFICATIONS See Figure 17 Pulse Width2 PW 50 ns CL = 2 nF, VDD2 = 12 V Maximum Data Rate3 1 MHz CL = 2 nF, VDD2 = 12 V Propagation Delay4 tDHL, tDLH 19 40 62 ns CL = 2 nF, VDD2 = 12 V ADuM3123 A Grade 25 46 68 ns CL = 2 nF, VDD2 = 4.5 V Propagation Delay Skew5 tPSK 12 ns CL = 2 nF, VDD2 = 12 V Output Rise Time/Fall Time (10% to 90%) tR/tF 1 12 24 ns CL = 2 nF, VDD2 = 12 V Supply Current Dynamic Input IDDI(D) 0.05 mA/Mbps VDD2 = 12 V Dynamic Output IDDO(D) 1.65 mA/Mbps VDD2 = 12 V Refresh Rate fr 1.2 Mbps VDD2 = 12 V 1 Short-circuit duration less than 1 µs. Average power must conform to the limits shown in the Absolute Maximum Ratings section. 2 The minimum pulse width is the shortest pulse width at which the specified timing parameter is guaranteed. 3 The maximum data rate is the fastest data rate at which the specified timing parameter is guaranteed. 4 tDHL propagation delay is measured from the input falling logic low threshold, VIL, to the output falling 90% threshold of the VO signal. tDLH propagation delay is measured from the time of the input rising logic high threshold, VIH, to the output rising 10% level of the VO signal. See Figure 17 for waveforms of propagation delay parameters. 5 tPSK is the magnitude of the worst case difference in tDLH and/or tDHL that is measured between units at the same operating temperature, supply voltages, and output load within the recommended operating conditions. See Figure 17 for waveforms of propagation delay parameters. Rev. 0 | Page 4 of 15 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety Related Specifications Regulatory Information DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Printed Circuit Board (PCB) Layout Propagation Delay Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide
