DatasheetsDatasheet ADuM3223/ADuM4223 (Analog Devices)
Description | 5 KV rms Isolated Precision Half-Bridge Driver, 4 A Output |
Pages / Page | 20 / 1 — Isolated Precision Half-Bridge Driver,. 4 A Output. Data Sheet. … |
Revision | J |
File Format / Size | PDF / 538 Kb |
Isolated Precision Half-Bridge Driver,. 4 A Output. Data Sheet. ADuM3223/. ADuM4223. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Isolated Precision Half-Bridge Driver, 4 A Output Data Sheet ADuM3223/ ADuM4223 FEATURES FUNCTIONAL BLOCK DIAGRAM 4 A peak output current ADuM3223/ Working voltage VIA 1 16 V ADuM4223 DDA High-side or low-side relative to input: 537 V peak V 2 ENCODE DECODE High-side to low-side differential: 800 V peak IB 15 VOA High frequency operation: 1 MHz maximum VDD1 3 14 GNDA 3.3 V to 5 V CMOS input logic GND 4.5 V to 18 V output drive 1 4 13 NC UVLO at 2.5 V VDD1 DISABLE 5 12 NC ADuM3223A/ ADuM4223A U VLO at 4.1 V VDD2 NC 6 11 V ADuM3223B/ ADuM4223B U VLO at 7.0 V V DDB DD2 ADuM3223C/ ADuM4223C U VLO at 11.0 V VDD2 NC 7 ENCODE DECODE 10 VOB Precise timing characteristics V 8 9 GND 54 ns maximum isolator and driver propagation delay DD1 B
001
5 ns maximum channel-to-channel matching NC = NO CONNECT
10450-
CMOS input logic levels
Figure 1.
High common-mode transient immunity: >25 kV/µs GENERAL DESCRIPTION Enhanced system-level ESD performance per IEC 61000-4-x High junction temperature operation: 125°C
The ADuM3223/ADuM42231 are 4 A isolated, half-bridge gate
Thermal shutdown protection
drivers that employ the Analog Devices, Inc., iCoupler® technology
Default low output
to provide independent and isolated high-side and low-side
Safety and regulatory approvals
outputs. The ADuM3223 provides 3000 V rms isolation in the
ADuM3223 n arrow-body, 16-lead SOIC
narrow body, 16-lead SOIC package, and the ADuM4223 provides
UL recognition per UL 1577
5000 V rms isolation in the wide body, 16-lead SOIC package.
3000 V rms for 1 minute SOIC long package
Combining high speed CMOS and monolithic transformer
CSA Component Acceptance Notice 5A
technology, these isolation components provide outstanding
VDE certificate of conformity
performance characteristics superior to the alternatives, such as
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12
the combination of pulse transformers and gate drivers.
VIORM = 560 V peak
The ADuM3223/ADuM4223 isolators each provide two
ADuM4223 wi de-body, 16-lead SOIC
independent isolated channels. They operate with an input
supply ranging from 3.0 V to 5.5 V, providing compatibility with
5000 V rms for 1 minute SOIC long package
lower voltage systems. In comparison to gate drivers employing
high voltage level translation methodologies, the ADuM3223/
ADuM4223 offer the benefit of true, galvanic isolation between
the input and each output. Each output may be continuously
VIORM = 849 V peak
operated up to 537 V peak relative to the input, thereby supporting
Qualified for automotive applications
low-side switching to negative voltages. The differential voltage
between the high-side and low-side may be as high as 800 V peak.
Switching power supplies
As a result, the ADuM3223/ADuM4223 provide reliable control
Isolated IGBT/MOSFET gate drives
over the switching characteristics of IGBT/MOSFET configurations
Industrial inverters
over a wide range of positive or negative switching voltages.
1 Protected by U.S. Patents 5,952,849; 6,873,065; 7,075,239. Other patents pending.
Rev. J Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety-Related Specifications ADuM3223 ADuM4223 Regulatory Information DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information PC Board Layout Propagation Delay-Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics Boot-Strapped Half-Bridge Operation DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
