Datasheet ADuM3223/ADuM4223 (Analog Devices) - 3
Description5 KV rms Isolated Precision Half-Bridge Driver, 4 A Output
Pages / Page20 / 3 — Data Sheet. ADuM3223/ADuM4223. SPECIFICATIONS ELECTRICAL …
RevisionJ
File Format / SizePDF / 538 Kb
Data Sheet. ADuM3223/ADuM4223. SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V OPERATION. Table 1. Parameter. Symbol. Min. Typ. Max. Unit
Data Sheet ADuM3223/ADuM4223 SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V OPERATION Table 1 Parameter Symbol Min Typ Max Unit
link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 9 link to page 15 link to page 15
All voltages are relative to their respective ground. 4.5 V ≤ VDD1 ≤ 5.5 V, 4.5 V ≤ VDD2 ≤ 18 V, unless stated otherwise. All minimum/ maximum specifications apply over TJ = −40°C to 125°C. Al typical specifications are at TJ = 25°C, VDD1 = 5 V, VDD2 = 12 V. Switching specifications are tested with CMOS signal levels.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions
DC SPECIFICATIONS Input Supply Current, Quiescent IDDI(Q) 1.4 2.4 mA Output Supply Current, Per Channel, Quiescent IDDO(Q) 2.3 3.2 mA Supply Current at 1 MHz VDD1 Supply Current IDD1(Q) 1.6 2.5 mA Up to 1 MHz, no load VDDA/VDDB Supply Current IDDA/IDDB(Q) 5.6 8.0 mA Up to 1 MHz, no load Input Currents IIA, IIB −1 +0.01 +1 µA 0 ≤ VIA, VIB ≤ VDD1 Logic High Input Threshold VIH 0.7 × VDD1 V Logic Low Input Threshold VIL 0.3 × VDD1 V Logic High Output Voltages VOAH, VOBH VDD2 – 0.1 VDD2 V IOx = −20 mA, VIx = VIxH Logic Low Output Voltages VOAL, VOBL 0.0 0.15 V IOx = +20 mA, VIx = VIxL Undervoltage Lockout, VDD2 Supply Positive Going Threshold VDD2UV+ 4.1 4.4 V A-grade Negative Going Threshold VDD2UV− 3.2 3.6 V A-grade Hysteresis VDD2UVH 0.5 V A-grade Positive Going Threshold VDD2UV+ 6.9 7.4 V B-grade Negative Going Threshold VDD2UV− 5.7 6.2 V B-grade Hysteresis VDD2UVH 0.7 V B-grade Positive Going Threshold VDD2UV+ 10.5 11.1 V C-grade Negative Going Threshold VDD2UV− 8.9 9.6 V C-grade Hysteresis VDD2UVH 0.9 V C-grade Output Short-Circuit Pulsed Current1 IOA(SC), IOB(SC) 2.0 4.0 A VDD2 = 12 V Output Pulsed Source Resistance ROA, ROB 0.3 1.1 3.0 Ω VDD2 = 12 V Output Pulsed Sink Resistance ROA, ROB 0.3 0.6 3.0 Ω VDD2 = 12 V THERMAL SHUTDOWN TEMPERATURES Junction Temperature Shutdown, Rising Edge TJR 150 °C Junction Temperature Shutdown, Falling Edge TJF 140 °C SWITCHING SPECIFICATIONS Pulse Width2 PW 50 ns CL = 2 nF, VDD2 = 12 V Maximum Data Rate3 1 MHz CL = 2 nF, VDD2 = 12 V Propagation Delay4 tDHL, tDLH 31 43 54 ns CL = 2 nF, VDD2 = 12 V; see Figure 20 ADuM3223A/ADuM4223A tDHL, tDLH 35 47 59 ns CL = 2 nF, VDD2 = 4.5 V; see Figure 20 Propagation Delay Skew5 tPSK 12 ns CL = 2 nF, VDD2 = 12 V; see Figure 20 Channel-to-Channel Matching6 tPSKCD 1 5 ns CL = 2 nF, VDD2 = 12 V; see Figure 20 tPSKCD 1 7 ns CL = 2 nF, VDD2 = 4.5 V; see Figure 20 Output Rise/Fall Time (10% to 90%) tR/tF 6 12 18 ns CL = 2 nF, VDD2 = 12 V; see Figure 20 Dynamic Input Supply Current Per Channel IDDI(D) 0.05 mA/Mbps VDD2 = 12 V Dynamic Output Supply Current Per Channel IDDO(D) 1.65 mA/Mbps VDD2 = 12 V Refresh Rate fr 1.2 Mbps 1 Short-circuit duration less than 1 µs. Average power must conform to the limit shown under the Absolute Maximum Ratings. 2 The minimum pulse width is the shortest pulse width at which the specified timing parameter is guaranteed. 3 The maximum data rate is the fastest data rate at which the specified timing parameter is guaranteed. 4 tDLH propagation delay is measured from the time of the input rising logic high threshold, VIH, to the output rising 10% level of the VOx signal. tDHL propagation delay is measured from the input falling logic low threshold, VIL, to the output falling 90% threshold of the VOx signal. See Figure 20 for waveforms of propagation delay parameters. 5 tPSK is the magnitude of the worst-case difference in tDLH and/or tDHL that is measured between units at the same operating temperature, supply voltages, and output load within the recommended operating conditions. See Figure 20 for waveforms of propagation delay parameters. 6 Channel-to-channel matching is the absolute value of the difference in propagation delays between the two channels. Rev. J | Page 3 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety-Related Specifications ADuM3223 ADuM4223 Regulatory Information DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information PC Board Layout Propagation Delay-Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics Boot-Strapped Half-Bridge Operation DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
