Datasheet ADuM3220/ADuM3221 (Analog Devices) - 7
DescriptionIsolated 4 A Dual-Channel Gate Driver
Pages / Page16 / 7 — Data Sheet. ADuM3220/ADuM3221. ABSOLUTE MAXIMUM RATINGS. Table 8. Table …
RevisionC
File Format / SizePDF / 622 Kb
Data Sheet. ADuM3220/ADuM3221. ABSOLUTE MAXIMUM RATINGS. Table 8. Table 9. Maximum Continuous Working Voltage1. Parameter. Rating
Data Sheet ADuM3220/ADuM3221 ABSOLUTE MAXIMUM RATINGS Table 8 Table 9 Maximum Continuous Working Voltage1 Parameter Rating
link to page 6 link to page 14 link to page 14 link to page 14 link to page 14 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
Ambient temperature = 25°C, unless otherwise noted.
Table 8. Table 9. Maximum Continuous Working Voltage1 Parameter Rating Parameter Max Unit Constraint
Storage Temperature (T ) −55°C to +150°C AC Bipolar Voltage2 565 V peak 50-year minimum lifetime ST Operating Temperature (T ) −40°C to +150°C AC Unipolar Voltage3 1131 V peak 50-year minimum lifetime J Supply Voltage Ranges1 DC Voltage4 1131 V peak 50-year minimum lifetime V −0.5 V to +7.0 V 1 DD1 Refers to the continuous voltage magnitude imposed across the isolation V −0.5 V to +20 V barrier. See the Insulation Lifetime section for more information. DD2 2 See Figure 24. Input Voltage Range (V , V )1, 2 −0.5 V to V + 0.5 V 3 IA IB DDI See Figure 25. Output Voltage Range (V , V )1, 2 −0.5 V to V + 0.5 V 4 See Figure 26. OA OB DDO Average Output Current per Pin (I )3 −23 mA to +23 mA O Common-Mode Transients, −100 kV/µs to +100 kV/µs
ESD CAUTION
(CM , CM )4 H L 1 All voltages are relative to their respective ground. 2 VDDI and VDDO refer to the supply voltages on the input and output sides of a given channel, respectively. 3 See Figure 3 for information about maximum allowable current for various temperatures. 4 Refers to common-mode transients across the insulation barrier. Common- mode transients exceeding the Absolute Maximum Rating can cause latch-up or permanent damage. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. C | Page 7 of 16 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information PC Board Layout Propagation Delay-Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
