Datasheet ADUM6132 (Analog Devices) - 3
DescriptionIsolated Half-Bridge Driver with Integrated Isolated High-Side Supply
Pages / Page16 / 3 — Data Sheet. ADuM6132. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. …
RevisionB
File Format / SizePDF / 318 Kb
Data Sheet. ADuM6132. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Min. Typ. Max. Unit
Data Sheet ADuM6132 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
All voltages are relative to their respective ground; 4.5 V ≤ VDD = VDDL ≤ 5.5 V; 12.5 V ≤ VDDB ≤ 17.0 V; VDDA = VISO. All minimum/maximum specifications apply over the entire recommended operating range, unless otherwise noted. All typical specifications are at TA = 25°C, VDD = VDDL = 5.0 V, VDDB = 15 V, VDDA = VISO.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
DC SPECIFICATIONS Isolated Power Supply Input Current, Quiescent IDD(Q) 280 mA IISO = 0 mA, dc signal inputs Input Current, Loaded IDD 350 mA IISO = IISO(MAX) Maximum Output Current1 IISO(MAX) 22 mA 12.5 V ≤ VISO ≤ 17.0 V Output Voltage VISO 12.5 15 17 V 0 mA ≤ IISO ≤ 22 mA Logic Supply Input Current IDDL 1.8 3.0 mA Output Supplies, Channel A or Channel B2 Supply Current, Quiescent IDDA(Q), IDDB(Q) 1.0 2.0 mA Supply Current, fIN = 20 kHz IDDA(20), IDDB(20) 1.1 2.1 mA CL = 200 pF Supply Current, fIN = 100 kHz IDDA(100), IDDB(100) 1.3 2.3 mA CL = 200 pF Supply Current, fIN = 1000 kHz IDDA(1000), IDDB(1000) 4.5 5.5 mA CL = 200 pF Logic Inputs, Channel A or Channel B Input Current IIA, IIB −10 +0.01 +10 µA 0 V ≤ VIA, VIB ≤ 5.5 V Logic High Input Voltage VIAH, VIBH 0.7 × VDDL V Logic Low Input Voltage VIAL, VIBL 0.3 × VDDL V Outputs, Channel A or Channel B Channel A High Level Output Voltage VOAH VDDA − 0.1 V IOAH = −1 mA Channel B High Level Output Voltage VOBH VDDB − 0.1 V IOBH = −1 mA Low Level Output Voltages VOAL,VOBL 0.1 V IOAL, IOBL = 1 mA High Level Output Current, Peak3 IOAH, IOBH 200 mA Low Level Output Current, Peak3 IOAL, IOBL 200 mA Undervoltage Lockout, VDDA or VDDB Supply4 Positive Going Threshold VDDAUV+, VDDBUV+ 11.0 11.7 12.3 V Negative Going Threshold VDDAUV−, VDDBUV− 10.0 10.7 11.2 V Hysteresis VDDAUVH, VDDBUVH 1.0 V Undervoltage Lockout, VDDL Supply4 Positive Going Threshold VDDLUV+ 3.5 4.2 V Negative Going Threshold VDDLUV− 3.1 3.8 V Hysteresis VDDLUVH 0.5 V SWITCHING SPECIFICATIONS Minimum Pulse Width1 PW 50 ns CL = 200 pF Maximum Switching Frequency1 fIN 1000 kHz CL = 200 pF Propagation Delay1 tPHL, tPLH 40 60 100 ns CL = 200 pF Change vs. Temperature 100 ps/°C Pulse Width Distortion, |tPLH − tPHL| PWD 10 ns CL = 200 pF Channel-to-Channel Matching, Rising or tM2 20 ns CL = 200 pF Falling Matching Edge Polarity1 Channel-to-Channel Matching, Rising vs. tM1 20 ns CL = 200 pF Falling Opposite Edge Polarity1 Rev. B | Page 3 of 16 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operation Conditions Absolute Maximum Values ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Applications Information Typical Application Usage PCB Layout Thermal Analysis Undervoltage Lockout Propagation Delay-Related Parameters Magnetic Field Immunity Insulation Lifetime Outline Dimensions Ordering Guide
