Datasheet ADUM6132 (Analog Devices) - 6
DescriptionIsolated Half-Bridge Driver with Integrated Isolated High-Side Supply
Pages / Page16 / 6 — ADuM6132. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. …
RevisionB
File Format / SizePDF / 318 Kb
ADuM6132. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. Rating. ESD CAUTION
ADuM6132 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating ESD CAUTION
link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
TA = 25°C, unless otherwise noted. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress
Table 7.
rating only; functional operation of the device at these or any
Parameter Rating
other conditions above those indicated in the operational Storage Temperature Range, TST −55°C to +150°C section of this specification is not implied. Exposure to absolute Ambient Operating Temperature −40°C to +85°C maximum rating conditions for extended periods may affect Range, TA device reliability. Input Supply Voltage, V 1 DDL, VDD −0.5 V to +7.0 V Channel A, Channel B Supply −0.5 V to +27 V Voltage, V 1 DDA, VDDB
ESD CAUTION
Input Voltage, V 1 IA, VIB −0.5 V to VDDL + 0.5 V Output Voltage, V 1 OA −0.5 V to VISO + 0.5 V Output Voltage, V 1 OB −0.5 V to VDDB + 0.5 V Average DC Output Current, −10 mA to +10 mA IOA, IOB Peak Output Current, IOA, IOB −200 mA to +200 mA Common-Mode Transients2 −100 kV/µs to +100 kV/µs 1 All voltages are relative to their respective ground. 2 Refers to common-mode transients across any insulation barrier. Common- mode transients exceeding the absolute maximum ratings can cause latch-up or permanent damage. Rev. B | Page 6 of 16 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operation Conditions Absolute Maximum Values ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Applications Information Typical Application Usage PCB Layout Thermal Analysis Undervoltage Lockout Propagation Delay-Related Parameters Magnetic Field Immunity Insulation Lifetime Outline Dimensions Ordering Guide
