Datasheet ADUM5230 (Analog Devices)
Description | Isolated Half-Bridge Driver with Integrated High-Side Supply |
Pages / Page | 15 / 1 — Isolated Half-Bridge Driver. with Integrated High-Side Supply. Data … |
Revision | C |
File Format / Size | PDF / 779 Kb |
Isolated Half-Bridge Driver. with Integrated High-Side Supply. Data Sheet. ADuM5230. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Isolated Half-Bridge Driver with Integrated High-Side Supply Data Sheet ADuM5230 FEATURES FUNCTIONAL BLOCK DIAGRAM Integrated, isolated high-side supply GND 1 16 1 V 150 mW of secondary side power OA ISOLATED DC-TO-DC Isolated high-side and low-side outputs CONVERTER VDD1 2 15 VISO 100 mA output source current, 300 mA output sink current High common-mode transient immunity: >25 kV/μs VADJ 3 14 GNDISO High temperature operation: 105°C Adjustable power level GND 4 13 1 DNC Wide body, 16-lead SOIC package ╓ ╓ V ENCODE DECODE 12 Safety and regulatory approvals IA 5 DNC ╜ ╜ UL recognition: 2500 V rms for 1 minute per UL1577 11 GND V ╓ ╓ B ENCODE DECODE Qualified for automotive applications IB 6 ╜ ╜ 10 APPLICATIONS VDD1 7 VDDB ADuM5230 MOSFET/IGBT gate drives GND 9
1
1 8 VOB
-00
DNC = DO NOT CONNECT. DO NOT CONNECT TO THIS PIN.
07
Motor drives
Figure 1.
Power supplies GENERAL DESCRIPTION
The ADuM52301 is an isolated half-bridge gate driver that In comparison to gate drivers employing high voltage level employs Analog Devices, Inc., iCoupler® technology to provide translation methodologies, the ADuM5230 offers the benefit independent and isolated high-side and low-side outputs. of true, galvanic isolation between the input and each output. Combining CMOS and microtransformer technologies, this Each output can operate up to ±700 VP relative to the input, isolation component contains an integrated dc-to-dc converter thereby supporting low-side switching to negative voltages. providing an isolated high-side supply. This eliminates the cost, The differential voltage between the high side and low side space, and performance difficulties associated with external may be as high as 700 VP. supply configurations such as bootstrap circuitry. This high- side isolated supply powers not only the ADuM5230 high-side output but also any external buffer circuitry used with the ADuM5230. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; 7,075,329; other pending patents.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2008–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFOMANCE CHARACTERISTICS APPLICATIONS INFORMATION THEORY OF OPERATION PRINTED CIRCUIT BOARD (PCB) LAYOUT THERMAL ANALYSIS PROPAGATION DELAY-RELATED PARAMETERS DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION INCREASING AND DECREASING AVAILABLE POWER COMMON-MODE TRANSIENT IMMUNITY TYPICAL APPLICATION USAGE INSULATION LIFETIME OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
