link to page 1 link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 4 link to page 4 link to page 4 link to page 5 link to page 5 link to page 6 link to page 6 link to page 7 link to page 7 link to page 8 link to page 8 link to page 8 link to page 9 link to page 10 link to page 10 link to page 12 link to page 13 link to page 14 link to page 15 link to page 15 link to page 15 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 19 link to page 20 CONFIDENTIALKP276C1505Digital Absolute Pressure SensorTable of contentsTable of contentsdTurboTMAP with SENT Output and Temperature Sensor Interface . .1 Features . 1 Potential applications . 1 Product validation . 1 Description . .1 Table of contents . 2 1Functional description . 4 1.1 Pin configuration . 4 1.2 Pin description . 4 1.3 Block Diagram . 5 1.4 Transfer function pressure . .5 1.4.1 Pressure transfer function characteristics . 6 1.4.2 Pressure accuracy . 6 1.5 Transfer function temperature . 7 1.5.1 Temperature transfer function characteristics . 7 1.6 SENT interface . 8 1.6.1 Physical layer . 8 1.6.2 Data link layer . 8 1.6.2.1 Nibble specification . 9 1.6.2.2 Status and communication nibble . 10 1.6.2.3 Enhanced serial message format . 10 1.6.2.4 Enhanced serial message data . 12 1.6.3 Pressure channel output codes . 13 1.6.4 Temperature channel output codes . 14 1.6.5 Diagnostic Error Codes . 15 1.6.5.1 Signal out of range . 15 1.6.5.2 Diag1 . .15 1.6.5.3 Diag2 . .16 1.6.5.4 EEPROM Check . .16 1.6.6 Definition of Pressure signal path latency . 16 1.7 External temperature sensor . .17 1.7.1 Linearization of the external temperature sensor transfer function . .17 1.7.2 Accuracy for NTC signal processing . 17 2Specification . 18 2.1 Application circuit example . .18 2.2 Application circuit example for EMC . 19 2.3 Absolute maximum ratings . 20 Datasheet 2 Revision 1.0 2019-01-25 Document Outline dTurboTMAP with SENT Output and Temperature Sensor Interface Features Potential applications Product validation Description Table of contents 1 Functional description 1.1 Pin configuration 1.2 Pin description 1.3 Block Diagram 1.4 Transfer function pressure 1.4.1 Pressure transfer function characteristics 1.4.2 Pressure accuracy 1.5 Transfer function temperature 1.5.1 Temperature transfer function characteristics 1.6 SENT interface 1.6.1 Physical layer 1.6.2 Data link layer 1.6.2.1 Nibble specification 1.6.2.2 Status and communication nibble 1.6.2.3 Enhanced serial message format 1.6.2.4 Enhanced serial message data 1.6.3 Pressure channel output codes 1.6.4 Temperature channel output codes 1.6.5 Diagnostic Error Codes 1.6.5.1 Signal out of range 1.6.5.2 Diag1 1.6.5.3 Diag2 1.6.5.4 EEPROM Check 1.6.6 Definition of Pressure signal path latency 1.7 External temperature sensor 1.7.1 Linearization of the external temperature sensor transfer function 1.7.2 Accuracy for NTC signal processing 2 Specification 2.1 Application circuit example 2.2 Application circuit example for EMC 2.3 Absolute maximum ratings 2.4 Operating range 2.5 Characteristics 3 Package information 3.1 PG-DSOF-8-162 Outline 3.2 Identification code Revision history Disclaimer
