Datasheet KP276C1505 (Infineon) - 3
ManufacturerInfineon
DescriptionMedia robust MAP sensor with digital interface
Pages / Page27 / 3 — CONFIDENTIAL. KP276C1505. Digital Absolute Pressure Sensor. Table of …
Revision01_00
CONFIDENTIAL. KP276C1505. Digital Absolute Pressure Sensor. Table of contents. Package information. Revision history. Disclaimer
CONFIDENTIAL KP276C1505 Digital Absolute Pressure Sensor Table of contents Package information Revision history Disclaimer
link to page 21 link to page 22 link to page 24 link to page 24 link to page 25 link to page 26 link to page 27
2.4 Operating range . 21 2.5 Characteristics . 22
3 Package information
. 24 3.1 PG-DSOF-8-162 Outline . 24 3.2 Identification code . 25
Revision history
. 26
Disclaimer
. 27 Datasheet 3 Revision 1.0 2019-01-25 Document Outline dTurboTMAP with SENT Output and Temperature Sensor Interface Features Potential applications Product validation Description Table of contents 1 Functional description 1.1 Pin configuration 1.2 Pin description 1.3 Block Diagram 1.4 Transfer function pressure 1.4.1 Pressure transfer function characteristics 1.4.2 Pressure accuracy 1.5 Transfer function temperature 1.5.1 Temperature transfer function characteristics 1.6 SENT interface 1.6.1 Physical layer 1.6.2 Data link layer 1.6.2.1 Nibble specification 1.6.2.2 Status and communication nibble 1.6.2.3 Enhanced serial message format 1.6.2.4 Enhanced serial message data 1.6.3 Pressure channel output codes 1.6.4 Temperature channel output codes 1.6.5 Diagnostic Error Codes 1.6.5.1 Signal out of range 1.6.5.2 Diag1 1.6.5.3 Diag2 1.6.5.4 EEPROM Check 1.6.6 Definition of Pressure signal path latency 1.7 External temperature sensor 1.7.1 Linearization of the external temperature sensor transfer function 1.7.2 Accuracy for NTC signal processing 2 Specification 2.1 Application circuit example 2.2 Application circuit example for EMC 2.3 Absolute maximum ratings 2.4 Operating range 2.5 Characteristics 3 Package information 3.1 PG-DSOF-8-162 Outline 3.2 Identification code Revision history Disclaimer
