Datasheet LTC2358-16 (Analog Devices) - 2
DescriptionBuffered Octal, 16-Bit, 200ksps/Ch Differential ±10.24V ADC with 30VP-P Common Mode Range
Pages / Page40 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2)
File Format / SizePDF / 3.3 Mb
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 2)
LTC2358-16
Supply Voltage (V TOP VIEW CC) ...–0.3V to (VEE + 40V) Supply Voltage (VEE) .. –17.4V to 0.3V + – Supply Voltage Difference (VCC – VEE) ..40V IN7 IN7 GND V EE GND V DD V DD GND V DDLBYP CS BUSY SDI Supply Voltage (V 48 47 46 45 44 43 42 41 40 39 38 37 DD) ..6V Supply Voltage (OVDD) ..6V Internal Regulated Supply Bypass (VDDLBYP) ... (Note 3) IN6– 1 36 SDO7 IN6+ 2 35 SDO–/SDO6 Analog Input Voltage IN5– 3 34 SDO+/SDO5 IN0+ to IN7+, IN5+ 4 33 SCKO–/SDO4 IN4– 5 32 SCKO+/SCKO IN0– to IN7– (Note 4) ...(V IN4+ 6 31 OV EE – 0.3V) to (VCC + 0.3V) DD IN3– 7 30 GND REFIN .. –0.3V to 2.8V IN3+ 8 29 SCKI–/SCKI IN2– 9 28 SCKI+/SDO3 REFBUF, CNV (Note 5) ... –0.3V to (VDD + 0.3V) IN2+ 10 27 SDI–/SDO2 Digital Input Voltage (Note 5) ... –0.3V to (OV IN1– 11 26 SDI+/SDO1 DD + 0.3V) IN1+ 12 25 SDO0 Digital Output Voltage (Note 5) .. –0.3V to (OVDD + 0.3V) Power Dissipation .. 500mW Operating Temperature Range 13 14 15 16 17 18 19 20 21 22 23 24 – + PD LTC2358C .. 0°C to 70°C IN0 IN0 GND V CC V EE GND CNV REFIN GND CMOS REFBUF LTC2358I ...–40°C to 85°C LVDS/ LTC2358H .. –40°C to 125°C LX PACKAGE Storage Temperature Range .. –65°C to 150°C 48-LEAD (7mm × 7mm) PLASTIC LQFP TJMAX = 150°C, θJA = 53°C/W
ORDER INFORMATION http://www.linear.com/product/LTC2358-16#orderinfo TRAY PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2358CLX-16#PBF LTC2358LX-16 48-Lead (7mm × 7mm) Plastic LQFP 0°C to 70°C LTC2358ILX-16#PBF LTC2358LX-16 48-Lead (7mm × 7mm) Plastic LQFP –40°C to 85°C LTC2358HLX-16#PBF LTC2358LX-16 48-Lead (7mm × 7mm) Plastic LQFP –40°C to 125°C Consult ADI Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ Rev A 2 For more information www.analog.com Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS CONVERTER CHARACTERISTICS DYNAMIC ACCURACY INTERNAL REFERENCE CHARACTERISTICS REFERENCE BUFFER CHARACTERISTICS DIGITAL INPUTS AND DIGITAL OUTPUTS POWER REQUIREMENTS POWER REQUIREMENTS ADC TIMING CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS CONFIGURATION TABLES FUNCTIONAL BLOCK DIAGRAM TIMING DIAGRAM APPLICATIONS INFORMATION BOARD LAYOUT PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
