Datasheet ADAR7251 (Analog Devices) - 10
Description | 4-Channel, 16-Bit, Continuous Time Data Acquisition ADC |
Pages / Page | 72 / 10 — ADAR7251. Data Sheet. tFSS. FS_ADC. tFSH. tSCKH. SCLK_ADC. tSCKL. 16-BIT … |
File Format / Size | PDF / 4.4 Mb |
ADAR7251. Data Sheet. tFSS. FS_ADC. tFSH. tSCKH. SCLK_ADC. tSCKL. 16-BIT CLOCKS PER CHANNEL. tDS. (16-BIT DATA). ADC_DOUTx. LEFT JUSTIFIED. MSB
ADAR7251 Data Sheet tFSS FS_ADC tFSH tSCKH SCLK_ADC tSCKL 16-BIT CLOCKS PER CHANNEL tDS (16-BIT DATA) t t DH ADC_DOUTx DD LEFT JUSTIFIED MSB MSB – 1 MODE tDH t tDS DD ADC_DOUTx MSB I2S MODE
04 0 7- 35 12 Figure 3. Serial Port Timing Master Mode
3 00 7- 235 1 Figure 4. Serial Output Port Timing Slave Mode
DATA_READY tDS tSCKH SCLK_ADC t t DH SCKL LJ: ADC_DOUTx MSB tDD
5
I2S: ADC_DOUTx MSB
-00
t
57
DD
123 Figure 5. PPI Timing Master Mode
tCSDR tDRH CONV_START
06 0
DATA_READY
57- 123 Figure 6. CONV_START to DATA_READY Timing Rev. 0 | Page 10 of 72 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Analog Channel Digital Input/Output Power Supply Digital Filter SPI Port Timing Serial/Peripheral Parallel Interface (PPI) Port Timing Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Low Speed Ramp Radar Analog Front End Main Channel Overview Σ-∆ Modulation and Digital Filtering Differential Input Configuration High-Pass Filter (HPF) Low-Pass Filter (LPF) Input Routing Equalizer (EQ) Using LNA/PGA, EQ, or the Input Capacitor Reference Auxiliary ADC Power Supply LDO Clock Requirements Crystal Oscillator PLL Integer Mode Fractional Mode PLL Lock Acquisition GPIO ADC Data Port ADC Serial Mode ADC Serial Master Mode ADC Serial Master Mode with ADC Serial Slave ADC PPI (Byte Wide Mode) ADC PPI Nibble Wide Mode DAQ Mode Using Multiple ADAR7251 Devices for Systems with More Than Four Channels Device Address R/ Register Address Data Bytes CRC PCB Layout Guidelines Register Summary Register Details Clock Control Register PLL Denominator Register PLL Numerator Register PLL Control Register PLL Status Register Master Enable Switch Register ADC Enable Register Power Enable Register Clear the ASIL errors Register Selects Which Errors to Mask Register ASIL Error Flag Register ASIL Error Code Register CRC Value, Bits[7:0] Register CRC Value Register Start Calculating the CRC Value of the Register Map Content Register Register Map CRC Calculation Done Register Register Map CRC Value, Bits[7:0] Register Register Map CRC Value, Bits[15:8] Register Low Noise Amplifier Gain Control Register Programmable Gain Amplifier Gain Control Register Signal Path for ADC 1 Through ADC 4 Register Decimator Rate Control Register High Pass Filter Control Register DAQ Mode Control Register Decimator Truncate Control Register Serial Output Port Control Register Parallel Port Control Register ADC Digital Output Mode Register Auxiliary ADC Read Value Registers Auxiliary ADC Sample Rate Selection Register Auxiliary ADC Mode Register MPx Pin Modes Registers MP Write Value Registers MP Read Value Registers SPI_CLK Pin Drive Strength and Slew Rate Register SPI_MISO Pin Drive Strength and Slew Rate Register Pin Drive Strength and Slew Rate Register SPI_MOSI Pin Drive Strength and Slew Rate Register ADDR15 Pin Drive Strength and Slew Rate Register Pin Drive Strength and Slew Rate Register FS_ADC Pin Drive Strength and Slew Rate Register Pin Drive Strength and Slew Rate Register SCLK_ADC Pin Drive Strength and Slew Rate Register ADC_DOUTx Pins Drive Strength and Slew Rate Registers DATA_READY Pin Drive Strength and Slew Rate Register XTAL Enable and Drive Register ADC Test Register Digital Filter Sync Enable Register CRC Enable/Disable Register Typical Application Circuit Outline Dimensions Ordering Guide Automotive Products
