Datasheet AK5704 (Asahi Kasei Microdevices) - 3
ManufacturerAsahi Kasei Microdevices
DescriptionLow-Power 4-ch 32-bit ADC with MIC-Amp
Pages / Page109 / 3 — [AK5704]. 9.15.10. Output. Selector.. 74. 9.16. I2C-bus. Control. …
[AK5704]. 9.15.10. Output. Selector.. 74. 9.16. I2C-bus. Control. Interface. .. 75. 9.17. Register. Map. ... 78. 9.18. Register. Definition. ... 80. 10
[AK5704] 9.15.10 Output Selector. 74 9.16 I2C-bus Control Interface . 75 9.17 Register Map .. 78 9.18 Register Definition .. 80 10
[AK5704] 9.15.10. Output Selector.. 74 9.16. I2C-bus Control Interface .. 75 9.17. Register Map ... 78 9.18. Register Definition ... 80 10. Recommended External Circuits .. 94 11. Control Sequence ... 97 11.1. Clock Set Up .. 97 11.1.1. PLL Master Mode .. 97 11.1.2. PLL Slave Mode (BCLK pin) ... 98 11.1.3. PLL Slave Mode (MCKI pin) .. 99 11.1.4. External Slave Mode ... 100 11.1.5. External Master Mode ... 101 11.2. Voice Activity Detection (1ch Mic) ... 102 11.3. Microphone Input Recording (4ch) .. 104 11.4. Stop of Clock ... 105 11.4.1. PLL Master Mode .. 105 11.4.2. PLL Slave Mode (BCLK pin) ... 105 11.4.3. PLL Slave Mode (MCKI pin) .. 105 11.4.4. External Slave Mode ... 106 11.4.5. External Master Mode ... 106 11.5. Power Down .. 106 12. Package .. 107 12.1. Outline Dimensions ... 107 12.2. Material & Lead finish .. 107 12.3. Marking .. 107 13. Ordering Guide ... 108 14. Revision History .. 108 IMPORTANT NOTICE .. 109 019000890-E-00 2019/02 - 3 - Document Outline 1. General Description 2. Features 3. Table of Contents 4. Block Diagram 5. Pin Configurations and Functions 5.1. Pin Configurations 5.2. Functions 5.3. Handling of Unused Pin 5.4. Pin State In Power-down Mode 6. Absolute Maximum Ratings 7. Recommended Operating Conditions 8. Electrical Characteristics 8.1. Microphone & ADC Analog Characteristics (AVDD=3.3V: AVDDL bit = “0”) 8.2. Microphone & ADC Analog Characteristics (AVDD=1.8V: AVDDL bit = “1”) 8.3. Power Supply Current 8.4. Power Consumption for Each Operation Mode 8.5. ADC1/2 Short Delay Sharp Roll-off Filter (ADVF bit = “0”) 8.6. ADC1/2 Digital Filter for Voice (ADVF bit = “1”) 8.7. DC Characteristics 8.8. Switching Characteristics 9. Functional Descriptions 9.1. Internal Pull-down Pin 9.2. LDO Circuit 9.3. System Clock 9.4. PLL 1. PLL Output Frequency (MCKO pin) 2. BCLK Output Frequency 3. Internal Block Diagram of PLL (3-1) PLL Reference Clock Divider (PLD) (3-2) PLL Feedback Clock Divider (PLM) 4. Adaptive Frequencies 5. Example of PLL Frequency Setting 9.5. Audio Interface Format 9.6. Synchronization with audio system (SYNCDET) 9.7. MIC/LINE Input 9.8. Microphone Amplifier Gain 9.9. Microphone Power 9.10. MIC Input Start-Up Time 9.11. ADC1/2 Initialization Cycle 9.12. Mono/Stereo Mode 9.13. Digital Microphone 9.14. Digital Block 9.14.1. Programmable Phase Adjustment 9.14.2. High Pass Filter (ADC1/2) 9.14.3. ADC1/2 Digital Filter 9.14.4. Microphone Sensitivity Adjustment 9.14.5. Monaural (MIX) Selection 9.14.6. High Pass Filter (HPF1/2) 9.14.7. Low Pass Filter (LPF1/2) 9.14.8. ALC Operation 9.14.9. Input Digital Volume (Manual Mode) 9.14.10. ALC 4ch Link Mode Sequence 9.15. Digital Voice Activity Detector 9.15.1. VDLY 9.15.2. HPF, LPF 9.15.3. ABS 9.15.4. NLD (Noise Level Detector) 9.15.5. MAX 9.15.6. MULT (X) 9.15.7. Comparator (>) 9.15.8. Guard Timer 9.15.9. Interrupt Output (WINTN pin) 9.15.10. Output Selector 9.16. I2C-bus Control Interface 9.17. Register Map 9.18. Register Definition 10. Recommended External Circuits 11. Control Sequence 11.1. Clock Set Up 11.1.1. PLL Master Mode 11.1.2. PLL Slave Mode (BCLK pin) 11.1.3. PLL Slave Mode (MCKI pin) 11.1.4. External Slave Mode 11.1.5. External Master Mode 11.2. Voice Activity Detection (1ch Mic) 11.3. Microphone Input Recording (4ch) 11.4. Stop of Clock 11.4.1. PLL Master Mode 11.4.2. PLL Slave Mode (BCLK pin) 11.4.3. PLL Slave Mode (MCKI pin) 11.4.4. External Slave Mode 11.4.5. External Master Mode 11.5. Power Down 12. Package 12.1. Outline Dimensions 12.2. Material & Lead finish 12.3. Marking 13. Ordering Guide 14. Revision History IMPORTANT NOTICE
