Datasheet RH1013M (Analog Devices) - 4
Description | Dual Precision Operational Amplifier |
Pages / Page | 6 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current (Per Amplifier). … |
Revision | F |
File Format / Size | PDF / 169 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current (Per Amplifier). Positive Slew Rate. Negative Slew Rate
RH1013M
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current (Per Amplifier) Positive Slew Rate Negative Slew Rate
0.8 0.8 0.8 VS = ±15V V V S = ±15V S = ±15V RL = 10k RL = 10k RL = 10k 0.6 0.6 0.6 0.4 0.4 0.4 SUPPLY CURRENT (mA) 0.2 0.2 0.2 POSITIVE SLEW RATE (V/µs) NEGATIVE SLEW RATE (V/µs) 0 0 0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1013M G01 RH1013M G02 RH1013M G03
Input Offset Voltage Input Bias Current
300 70 VS = ±15V VS = ±15V VCM = 0V 60 VCM = 0V 200 50 100 40 0 30 –100 20 INPUT BIAS CURRENT (nA) INPUT OFFSET VOLTAGE (µV) –200 10 –300 0 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1013M G04 RH1013M G05
Input Offset Current Open-Loop Gain
150 3 V V S = ±15V S = ±15V V 140 RL = 10k CM = 0V VOUT = ±10V 2 130 1 120 110 0 OPEN-LOOP GAIN (dB) 100 INPUT OFFSET CURRENT (nA) –1 90 80 –2 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1013M G07 RH1013M G06 Rev. F 4 For more information www.analog.com Document Outline Description Burn-In Circuit Package/Order Information Absolute Maximum Ratings Total Dose Bias Circuit Table 1: Electrical characteristics Table 1a: Electrical characteristics Table 2: Electrical Test Requirements Typical Performance Characteristics Revision History Rad Hard
