Datasheet RH1014M (Analog Devices) - 5
DescriptionQuad Precision Operational Amplifier
Pages / Page6 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias …
RevisionH
File Format / SizePDF / 564 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias Current. Input Offset Current. Open-Loop Gain
TYPICAL PERFORMANCE CHARACTERISTICS Input Offset Voltage Input Bias Current Input Offset Current Open-Loop Gain
RH1014M
300 70 3 VS = ±15V VS = ±15V VS = ±15V V 60 VCM = 0V V 200 CM = 0V CM = 0V 2 50 100 1 40 0 30 0 –100 20 INPUT OFFSET VOLTAGE (µV) INPUT BIAS CURRENT (nA) –200 INPUT OFFSET CURRENT (nA) –1 10 –300 0 –2 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1014M G04 RH1014M G05 RH1014M G06
Open-Loop Gain Common-Mode Rejection Ratio Power Supply Rejection Ratio
150 140 150 V V S = ±15V V S = ±10V TO ±18V S = ±15V 140 RL = 10k –15V ≤ V 130 V 140 CM ≤ 13.5V OUT = ±10V 130 120 130 120 110 120 110 100 110 OPEN-LOOP GAIN (dB) 100 90 100 90 80 90 POWER SUPPLY REJECTION RATIO (dB) COMMON-MODE REJECTION RATIO (dB) 80 70 1 10 100 1000 80 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1014M G07 RH1014M G09 RH1014M G08
Input Noise Voltage Density Gain Bandwidth Product
100 1000 90 VS = ±15V 900 VS = ±5V fO = 10Hz RL = 10k 80 800 70 700 60 600 50 500 40 400 30 300 20 200 GAIN BANDWIDTH PRODUCT (kHz) 10 100 INPUT NOISE VOLTAGE DENSITY (nV/√Hz) 0 0 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1014M G10 RH1014M G11 Rev. H Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications For more information www.a subject to change without notice. No license is granted by implication or other nalog.com wise under any patent or patent rights of Analog Devices. 5 Document Outline Description Burn-In Circuit Absolute Maximum Ratings Package Information Table 1: Electrical characteristics Table 1a: Electrical characteristics Table 2: Electrical Test Requirements Total Dose Bias Circuit Typical Performance Characteristics Revision History
