Datasheet RH118 (Analog Devices) - 2
DescriptionPrecision, High Speed Operational Amplifier
Pages / Page4 / 2 — TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 3). TA = 25. …
RevisionC
File Format / SizePDF / 671 Kb
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 3). TA = 25. SUB-. 125. SYMBOL PARAMETER. CONDITIONS. NOTES. MIN. TYP. MAX
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 3) TA = 25 SUB- 125 SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX
RH118
C SUB-
55
C
TA
125
C SUB- SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX GROUP MIN TYP MAX GROUP UNITS
VOS Input Offset Voltage 4 1 6 2,3 mV IOS Input Offset Current 50 1 100 2,3 nA IB Input Bias Current 250 1 500 2,3 nA RIN Input resistance 4 1 MΩ AV Large-Signal VS = ±15V, VOUT = ±10V 50 1 25 2,3 V/mV Voltage Gain RL ≥ 2k SR Slew Rate VS = ±15V, AV = 1 5 50 V/µs GBW Gain Bandwidth VS = ±15V 15 MHz Product Output Voltage VS = ±15V, RL = 2k ±12 4 ±12 5,6 V Swing Input Voltage VS = ±20V ±16.5 1 ±16.5 2,3 V Range IS Supply Current 8 1 mA TA = 125˚C 7 2 mA CMRR Common Mode 80 1 80 2,3 dB Rejection Ratio PSRR Power Supply 70 1 70 2,3 dB Rejection Ratio
TABLE 1A: ELECTRICAL CHARACTERISTICS (Postirradiation) (Note 6) 10Krad(Si) 20Krad(Si) 50Krad(Si) 100Krad(Si) 200Krad(Si SYMBOL PARAMETER CONDITIONS NOTES MIN MAX MIN MAX MIN MAX MIN MAX MIN MAX UNITS
VOS Input Offset Voltage 4 4 4 4 10 mV IOS Input Offset Current 50 50 50 50 100 nA IB Input Bias Current 250 250 250 300 400 nA RIN Input Resistance 4 1 1 1 0.5 0.5 MΩ AV Large-Signal Voltage VS = ±15V, VOUT = ±10V 50 50 50 50 25 V/mV Gain RL ≥ 2k SR Slew Rate VS = ±15V, AV = 1 5 50 50 50 50 50 V/µs GBW Gain Bandwidth VS = ±15V 15 15 15 15 15 MHz Product (Typ) (Typ) (Typ) (Typ) (Typ) Output Voltage Swing VS = ±15V, RL = 2k ±12 ±12 ±12 ±12 ±12 V Input Voltage Range ±16.5 ±16.5 ±16.5 ±15 ±12 V IS Supply Current 8 8 8 8 8 mA CMRR Common Mode 80 80 80 80 70 dB Rejection Ratio PSRR Power Supply 70 70 70 70 60 dB Rejection Ratio I.D.No.66-11-0118 Rev. C 2 For more information www.analog.com Document Outline Description Burn-In Circuit Package/Order Information Absolute Maximum Ratings Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Electrical Characteristics Total Dose Bias Circuit Table 2: Electrical Test Requirements Revision History
