Datasheet AD9213 (Analog Devices) - 3
Description12-Bit, 10.25 GSPS, JESD204B, RF Analog-to-Digital Converter
Pages / Page97 / 3 — Preliminary Technical Data. AD9213. SPECIFICATIONS DC SPECIFICATIONS. …
RevisionPrG
Preliminary Technical Data. AD9213. SPECIFICATIONS DC SPECIFICATIONS. Table 1. Test Conditions/. AD9213-6G. AD9213-10G. Parameter
Preliminary Technical Data AD9213 SPECIFICATIONS DC SPECIFICATIONS Table 1 Test Conditions/ AD9213-6G AD9213-10G Parameter
link to page 4 link to page 4 link to page 4 link to page 4
Nominal supply voltages, specified maximum sampling rate, internal reference, AIN = −1.0 dBFS.
Table 1. Test Conditions/ AD9213-6G AD9213-10G Parameter Comments Temperature1 Min Typ Max Min Typ Max Unit
RESOLUTION 12 12 Bits ACCURACY No Missing Codes Full Guaranteed Guaranteed Offset Error Full LSB Gain Error Full %FSR Differential Nonlinearity (DNL) Full LSB Integral Nonlinearity (INL) Full LSB ANALOG INPUTS Differential Input Voltage Range Internal VREF = Full 1.4 1.4 V p-p Resistance 70°C 50 50 Ω Capacitance 70°C 1 1 pF Internal Common-Mode Voltage (VCM) Full 0.5 0.5 V Analog Full-Power Bandwidth Internal termination 70°C 6.5 6.5 GHz Input Referred Noise 70°C LSBRMS POWER SUPPLIES BVDD2 70°C 2.0 2.0 V BVNN1 70°C −1.0 −1.0 V AVNN1 70°C −1.0 −1.0 V BVNN2 Internally generated 70°C −2.0 −2.0 V BVDD3 Internally generated 70°C 3.0 3.0 V AVDD 70°C 1.0 1.0 V CLKVDD_LF 70°C 1.0 1.0 V CLKVDD_HF 70°C 1.0 1.0 V PLLVDD2 70°C 2.0 2.0 V AVDDFS8 70°C 1.0 1.0 V FVDD 70°C 1.0 1.0 V VDD_NVG 70°C 1.0 1.0 V RVDD2 70°C 2.0 2.0 V SVDD2 70°C 2.0 2.0 V JVDD2 70°C 2.0 2.0 V DVDD 70°C 1.0 1.0 V JVTT 70°C 1.0 1.0 V JVDD 70°C 1.0 1.0 V TMU_AVDD2 70°C 2.0 2.0 V TMU_DVDD1 70°C 1.0 1.0 V IBVDD2 70°C 111 136 mA I 2 BVNN1 + IAVNN1 70°C 122 122 mA I 3 BVNN2 70°C mA I 3 BVDD3 70°C mA IAVDD 70°C 1750 2250 mA ICLKVDD_LF 70°C 30 33 mA ICLKVDD_HF 70°C 40 66 mA IPLLVDD2 70°C 71 71 mA IFVDD 70°C 25 30 mA Rev. PrG | Page 3 of 97 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9213-6G AD9213-10G EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Differential Input Configurations Input Common Mode Input Overvoltage Clamp VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Clock Synthesis Clock Jitter Considerations Power-Down/Standby Mode Temperature Diode and Sensor TMU ADC FAST DETECT FAST THRESHOLD DETECTION (FD) DIGITAL DOWNCONVERTER DDC GENERAL DESCRIPTION Frequency Translation Stage (Optional) Filtering Stage Gain Stage (Optional) Complex to Real Conversion Stage (Optional) DDC FREQUENCY TRANSLATION Variable IF Mode ZIF Mode fS/4 Hz IF Mode Test Mode DDC NCO Description DDC NCO Programmable Modulus Mode DDC NCO Coherent Mode NCO FTW/POW/MAW/MAB Description NCO FTW/POW/MAW/MAB Programmable Modulus Mode Example Calculation NCO FTW/POW/MAW/MAB Coherent Mode Example Calculation NCO Channel Selection GPIO Level Control Mode GPIO Edge Control Mode Profile Select Timer Mode Register Map Mode Setting Up the Multichannel NCO Feature NCO Synchronization NCO Multichip Synchronization NCO Multichip Synchronization at Startup NCO Multichip Synchronization during Normal Operation DDC Mixer Description DDC NCO + Mixer Loss and SFDR DDC DECIMATION FILTERS M2_HB7 Filter Description M2_HB6 Filter Description M2_HB5 Filter Description M2_HB4 Filter Description M2_HB3 Filter Description M2_HB2 Filter Description M2_HB1 Filter Description M1_TB2 Filter Description DDC GAIN STAGE DDC COMPLEX TO REAL CONVERSION DDC EXAMPLE CONFIGURATIONS DIGITAL OUTPUTS INTRODUCTION TO THE JESD204B INTERFACE JESD204B OVERVIEW FUNCTIONAL OVERVIEW Transport Layer Data Link Layer Physical Layer JESD204B LINK ESTABLISHMENT Code Group Synchronization (CGS) and SYNCINB± Initial Lane Alignment Sequence (ILAS) User Data and Error Detection 8-Bit/10-Bit Encoder PHYSICAL LAYER (DRIVER) OUTPUTS Digital Outputs, Timing, and Controls De-Emphasis Phase-Locked Loop SETTING UP THE AD9213 DIGITAL INTERFACE JESD204B Transport Layer Settings Serial Line Rates K Settings DETERMINISTIC LATENCY SUBCLASS 0 OPERATION SUBCLASS 1 OPERATION Deterministic Latency Requirements Setting Deterministic Latency Registers MULTICHIP SYNCHRONIZATION SAMPLED SYSREF MODE AVERAGED SYSREF MODE TEST MODES JESD204B TEST MODES SERIAL PORT INTERFACE MEMORY MAP READING THE MEMORY MAP REGISTER TABLES Open and Reserved Locations Default Values Logic Levels SPI Soft Reset REGISTER DETAILS: SYSTEM CONTROL SIGNALS (SPI_ONLY_REGMAP) REGISTER DETAILS: (USER_CTRL) REGISTER DETAILS: (AD9213_CUST_SPI_REGMAP) REGISTER DETAILS: (MAIN_REGMAP) REGISTER DETAILS: JTX_QBF REGISTER REGISTER DETAILS: DIG_DP_REGMAP REGISTER DETAILS: (AD9213_CUST_REG) REGISTER DETAILS: LCPLL_28NM REGISTER REGISTER DETAILS: JESD204B REGISTER MAP FOR FOUR CHANNELS (JTX_28NM_16CH) APPLICATIONS INFORMATION POWER SUPPLY RECOMMENDATIONS OUTLINE DIMENSIONS
