Datasheet AD8285 (Analog Devices) - 4
DescriptionRadar Receive Path AFE: 4-Channel LNA/PGA/AAF with ADC
Pages / Page27 / 4 — AD8285. Data Sheet. Parameter2 Test. Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 511 Kb
AD8285. Data Sheet. Parameter2 Test. Conditions/Comments. Min. Typ. Max. Unit
AD8285 Data Sheet Parameter2 Test Conditions/Comments Min Typ Max Unit
ADC Resolution 12 Bits Maximum Sample Rate 72 MSPS Signal-to-Noise Ratio (SNR) fIN = 1 MHz 68.5 dB Signal-to-Noise and Distortion 66 dB (SINAD) Signal-to-Noise Ratio Full Scale 68 dB (SNRFS) Differential Nonlinearity (DNL) Guaranteed no missing codes 1 LSB Integral Nonlinearity (INL) 10 LSB Effective Number of Bits (ENOB) 10.67 LSB ADC OUTPUT CHARACTERISTICS Maximum Capacitor Load Per bit 20 pF IDVDD33 Peak Current with Capacitor Peak current per bit when driving 20 pF load; 40 mA Load can be programmed via the SPI port, if required ADC REFERENCE Output Voltage Error VREF = 1.024 V ±25 mV Load Regulation At 1.0 mA, VREF = 1.024 V 2 mV Input Resistance 6 kΩ FULL CHANNEL CHARACTERISTICS LNA, PGA, AAF, and ADC channels SNRFS fIN = 1 MHz Gain = 16 dB 68 dB Gain = 22 dB 68 dB Gain = 28 dB 68 dB Gain = 34 dB 66 dB SINAD fIN = 1 MHz Gain = 16 dB 67 dB Gain = 22 dB 68 dB Gain = 28 dB 67 dB Gain = 34 dB 66 dB Spurious-Free Dynamic Range fIN = 1 MHz (SFDR) Gain = 16 dB 68 dB Gain = 22 dB 74 dB Gain = 28 dB 74 dB Gain = 34 dB 73 dB Harmonic Distortion Second Harmonic fIN = 1 MHz at −10 dBFS, gain = 16 dB −70 dBc fIN = 1 MHz at −10 dBFS, gain = 34 dB −70 dBc Third Harmonic fIN = 1 MHz at −10 dBFS, gain = 16 dB −66 dBc fIN = 1 MHz at −10 dBFS, gain = 34 dB −75 dBc IM3 Distortion fIN1 = 1 MHz, fIN2 = 1.1 MHz, −1 dBFS, gain = 34 dB −69 dBc Gain Response Time 600 ns Overdrive Recovery Time 200 ns 1 x stands for A, B, C, or D. 2 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for a complete set of definitions, and how these tests were completed. Rev. B | Page 4 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RADAR RECEIVE PATH AFE CHANNEL OVERVIEW Low Noise Amplifier (LNA) Recommendation Antialiasing Filter (AAF) Mux and Mux Controller ADC CLOCK INPUT CONSIDERATIONS CLOCK DUTY CYCLE CONSIDERATIONS CLOCK JITTER CONSIDERATIONS SDIO PIN SCLK PIN CS\ PIN RBIAS PIN VOLTAGE REFERENCE POWER AND GROUND RECOMMENDATIONS EXPOSED PADDLE THERMAL HEAT SLUG RECOMMENDATIONS SERIAL PERIPHERAL INTERFACE (SPI) HARDWARE INTERFACE MEMORY MAP READING THE MEMORY MAP TABLE LOGIC LEVELS RESERVED LOCATIONS DEFAULT VALUES APPLICATION DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
