Datasheet LT6654BX (Analog Devices) - 4
Description | 175°C, Wide Supply 2.5V Precision Voltage Reference |
Pages / Page | 14 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. The test conditions are TA = 25°C, … |
File Format / Size | PDF / 1.2 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS. The test conditions are TA = 25°C, CIN = 0.1μF,
LT6654BX
TYPICAL PERFORMANCE CHARACTERISTICS The test conditions are TA = 25°C, CIN = 0.1μF, COUT= 1μF, IOUT=0A and VIN = VOUT + 0.5V, unless otherwise noted. 2.5V Output Voltage 2.5V Output Voltage Extended 2.5V Temperature Drift Temperature Drift Temperature Drift Distribution
2.510 2.580 18 THREE TYPICAL PARTS THREE TYPICAL PARTS –40°C TO 125°C 2.508 2.570 16 2.560 14 2.506 2.550 TS 12 AR TAGE (V) 2.504 TAGE (V) 2.540 10 2.502 2.530 8 2.520 6 OUTPUT VOL 2.500 OUTPUT VOL NUMBER OF P 2.510 4 2.498 2.500 2 2.496 2.490 0 –45 –25 –5 15 35 55 75 95 115 135 155 175 –60 –30 0 30 60 90 120 150 180 210 –10 –8 –6 –4 –2 0 2 4 6 8 10 TEMPERATURE (°C) TEMPERATURE (°C) DRIFT (ppm/°C) 6654BX G01 6654BX G02 6654BX G03
2.5V Temperature Drift Distribution 2.5V VOUT Distribution 2.5V VOUT Distribution
10 18 18 –40°C TO 175°C TA = 125°C TA = 175°C 9 16 16 8 14 14 7 TS TS 12 TS 12 AR 6 AR AR 10 10 5 8 8 4 NUMBER OF P 6 6 3 NUMBER OF P NUMBER OF P 2 4 4 1 2 2 0 0 0 10 12 14 16 18 20 22 24 26 28 30 –0.12 –0.08 –0.04 0.00 0.04 0.08 0.12 0.20 0.25 0.30 0.35 0.40 0.45 0.50 DRIFT (ppm/°C) VOUT ACCURACY (%) VOUT ACCURACY (%) 6654BX G04 6654BX G05 6654BX G06
2.5V Supply Current vs 2.5V Line Regulation vs Supply Voltage Supply Voltage
600 20 2.5105 VIN = 3V TA = 175°C, VIN = 3V MS8 PACKAGE PART 500 16 SELF HEATING IS INCLUDED 2.5100 OUTPUT VOL 400 12 2.5095 300 TION (ppm/V) 8 2.5090 TAGE (V) Y CURRENT (µA) 200 4 2.5085 SUPPL 175°C LINE REGULA 100 125°C 0 2.5080 25°C OUTPUT VOLTAGE –40°C LINE REGULATION 0 –4 2.5075 0 6 12 18 24 30 36 4 8 12 16 20 24 28 32 36 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) 6654BX G07 6654BX G08 Rev. 0 4 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Package Description Typical Application Related Parts
