Datasheet ADL5246 (Analog Devices) - 10
Description3 GHz Variable Gain LNA with Integrated ½ W Driver Amplifier
Pages / Page36 / 10 — ADL5246. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 35.0. Bm) d 35. …
ADL5246. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 35.0. Bm) d 35. 32.5. d (. OIP3, 3.3V. ), 5. 40. 30.0. , 3. URE. Bm). F 25. 27.5
ADL5246 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 35.0 Bm) d 35 32.5 d ( OIP3, 3.3V ), 5 40 30.0 , 3 URE Bm) F 25 27.5
All supply pins at 5 V, TA = 25°C, unless otherwise noted.
40 35 50 35.0 Bm) d 35 30 B, 45 32.5 d ( 0V OIP3, 3.3V 3V 30 25 ), 5. 40 30.0 , 3. URE m IG B Bm) d d F 25 20 Bm) ( ( E d 35 27.5 ( B B IS B 1d 1d P OIP3, 5.0V TA = –40°C P 20 15 1d O 30 25.0 P T O A = +25°C T 1 O A = +85°C 15 10 P AND 25 OP1dB, 5.0V TA = +105°C 22.5 AND 3, AND NO 3 3 IP GAIN, 5.0V AM IP IP OIP3, 5.0V , O 10 NOISE FIGURE, 5.0V 5 1 O 20 20.0 1 O N GAIN, 3.3V P P AI OIP3, 3.3V NOISE FIGURE, 3.3V AM AM 1 G 5 0 15 17.5 OP1dB, 3.3V P OP1dB, 5.0V OP1dB, 3.3V AM 0 –5 10 15.0 0.6 1.0 1.4 1.8 2.2 2.6 3.0
3 06 00
0 3- 3-
FREQUENCY (GHz)
23
FREQUENCY (GHz)
23 12 12 Figure 3. AMP1 Gain, OIP3 at POUT = 0 dBm/Tone, Noise Figure, Figure 6. AMP1 OIP3 at POUT = 0 dBm/Tone and OP1dB vs. and OP1dB vs. Frequency Frequency by Temperature
24 48 40 TA = –40°C T 38 20 A = +25°C 40 TA = +85°C TA = +105°C 36 V V 16 32 ) 5.0 3.3 m ), ), 34 B B B d d (d ( ( 12 24 IN IN IP3 32 O 1 GA 1 GA P1 0.9GHz, 5.0V P P M 30 1.9GHz, 5.0V M 8 16 M A A A 2.6GHz, 5.0V 0.9GHz, 3.3V 28 1.9GHz, 3.3V 4 8 2.6GHz, 3.3V 26 0 0 24 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 3.0
04 07 0
–10 –5 0 5 10 15
0 3- 3-
FREQUENCY (GHz)
23
P
223 12
OUT (dBm)
1 Figure 4. AMP1 Gain vs. Frequency by Temperature Figure 7. AMP1 OIP3 vs. POUT by Frequency
0 3.0 TA = –40°C, 5.0V –5 TA = –40°C, 3.3V 2.5 TA = +25°C, 5.0V TA = +25°C, 3.3V –10 ) ) B T B A = +85°C, 5.0V (d T (d 2.0 A = +85°C, 3.3V –15 TA = +105°C, 5.0V URE UDE TA = +105°C, 3.3V T IG NI –20 F 1.5 E AG IS 1 M –25 P 1 NO 1.0 S11, 5.0V P AM –30 S12, 5.0V AM S22, 5.0V S11, 3.3V 0.5 –35 S12, 3.3V S22, 3.3V –40 0 0.6 1.0 1.4 1.8 2.2 2.6 3.0
05 08 0
0 3- 3-
FREQUENCY (GHz)
23
FREQUENCY (GHz)
23 12 12 Figure 5. AMP1 Magnitude of Input Return Loss (S11), Output Return Loss (S22), Figure 8. AMP1 Noise Figure vs. Frequency by Temperature and Reverse Isolation (S12) vs. Frequency Rev. A | Page 10 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION BASIC CONNECTIONS Amplifier 1 (AMP1) Amplifier 2 (AMP2) Amplifier 3 (AMP3) Gain Control Amplifier 3 Matching ERROR VECTOR MAGNITUDE (EVM) PERFORMANCE THERMAL INFORMATION AND RECOMMENDED PCB LAND PATTERN FULL CHAIN OPERATION CONSIDERATIONS EVALUATION BOARD CHARACTERIZATION INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
