Datasheet ADL5246 (Analog Devices) - 3
Description3 GHz Variable Gain LNA with Integrated ½ W Driver Amplifier
Pages / Page36 / 3 — Data Sheet. ADL5246. SPECIFICATIONS. Table 1. 3.3 V. 5 V. Parameter. Test …
Data Sheet. ADL5246. SPECIFICATIONS. Table 1. 3.3 V. 5 V. Parameter. Test Conditions/Comments. Min. Typ. Max. Min Typ. Max Unit
Data Sheet ADL5246 SPECIFICATIONS Table 1 3.3 V 5 V Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
VPOS = 5 V, TA = 25°C, unless otherwise noted. Amplifier 1 = AMP1, Amplifier 2 = AMP2, and Amplifier 3 = AMP3.
Table 1. 3.3 V 5 V Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
OVERALL FUNCTION Frequency Range 0.6 3 0.6 3 GHz AMP1 FREQUENCY = 0.75 GHz RFIN1 and RFOUT1 pins Gain 19.5 20 dB vs. Frequency ±50 MHz ±0.3 ±0.3 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.6 ±0.5 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V ±0.1 ±0.05 dB Input Return Loss S11 −21 −22 dB Output Return Loss S22 −9 −9 dB Output 1 dB Compression 18.5 21.5 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 31 34.5 dBm Noise Figure 1.4 1.5 dB AMP1 FREQUENCY = 0.9 GHz RFIN1 and RFOUT1 pins Gain 19 18.5 dB vs. Frequency ±50 MHz ±0.4 ±0.4 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.5 ±0.5 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V ±0.1 ±0.05 dB Input Return Loss S11 −21 −24 dB Output Return Loss S22 −11 −10 dB Output 1 dB Compression 19 22 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 32 35 dBm Noise Figure 0.9 1.2 dB AMP1 FREQUENCY = 1.5 GHz RFIN1 and RFOUT1 pins Gain 15 14.5 dB vs. Frequency ±100 MHz ±0.7 ±0.4 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.4 ±0.5 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V ±0.1 ±0.1 dB Input Return Loss S11 −14.5 −16 dB Output Return Loss S22 −14 −12 dB Output 1 dB Compression 19 22.5 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 33 37 dBm Noise Figure 0.8 0.85 dB AMP1 FREQUENCY = 1.9 GHz RFIN1 and RFOUT1 pins Gain 12.5 13 dB vs. Frequency ±100 MHz ±0.5 ±0.5 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.5 ±0.5 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V ±0.1 ±0.05 dB Input Return Loss S11 −13 −14 dB Output Return Loss S22 −14 −12 dB Output 1 dB Compression 19 22.5 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 34 37.5 dBm Noise Figure 0.9 0.9 dB Rev. A | Page 3 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION BASIC CONNECTIONS Amplifier 1 (AMP1) Amplifier 2 (AMP2) Amplifier 3 (AMP3) Gain Control Amplifier 3 Matching ERROR VECTOR MAGNITUDE (EVM) PERFORMANCE THERMAL INFORMATION AND RECOMMENDED PCB LAND PATTERN FULL CHAIN OPERATION CONSIDERATIONS EVALUATION BOARD CHARACTERIZATION INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
