Datasheet ADL5246 (Analog Devices) - 4
Description3 GHz Variable Gain LNA with Integrated ½ W Driver Amplifier
Pages / Page36 / 4 — ADL5246. Data Sheet. 3.3 V. 5 V. Parameter. Test Conditions/Comments. …
ADL5246. Data Sheet. 3.3 V. 5 V. Parameter. Test Conditions/Comments. Min. Typ. Max. Min Typ. Max Unit
ADL5246 Data Sheet 3.3 V 5 V Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
AMP1 FREQUENCY = 2.2 GHz RFIN1 and RFOUT1 pins Gain 11 11.5 dB vs. Frequency ±100 MHz ±0.5 ±0.5 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.5 ±0.5 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V ±0.05 ±0.05 dB Input Return Loss S11 −11 −12 dB Output Return Loss S22 −15 −12 dB Output 1 dB Compression 19 22.3 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 34 37.5 dBm Noise Figure 1 1 dB AMP1 FREQUENCY = 2.6 GHz RFIN1 and RFOUT1 pins Gain 10 10 dB vs. Frequency ±100 MHz ±0.4 ±0.5 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.4 ±0.5 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V ±0.05 ±0.05 dB Input Return Loss S11 −10 −11 dB Output Return Loss S22 −17 −13 dB Output 1 dB Compression 19.5 22.5 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 34 37.4 dBm Noise Figure 1.2 1.2 dB AMP2 FREQUENCY = 0.75 GHz RFIN2 to RFOUT2 at maximum gain Gain 12.5 16 dB vs. Frequency ±50 MHz ±0.4 ±0.4 dB vs. Temperature −40°C ≤ TA ≤ +105°C +3 to −4 +0.5 to −2 dB Gain Range HG mode 15 60 dB Input Return Loss −10 −9 dB Output Return Loss −29 −16 dB Input 1 dB Compression 2 4.5 dBm Point Input Third Order Intercept ∆f = 1 MHz, PIN = −5 dBm/tone 13 15 dBm Noise Figure 4.5 3.5 dB AMP2 FREQUENCY = 0.9 GHz RFIN2 to RFOUT2 at maximum gain Gain 11.5 14.5 dB vs. Frequency ±50 MHz ±0.5 ±0.5 dB vs. Temperature −40°C ≤ TA ≤ +105°C +2.5 to −4 +0.5 to −2 dB Gain Range HG mode 15 60 dB Input Return Loss −9.5 −9 dB Output Return Loss −21 −15 dB Input 1 dB Compression 3.5 5.5 dBm Point Input Third Order Intercept ∆f = 1 MHz, PIN = −5 dBm/tone 14 15.5 dBm Noise Figure 4.2 3.2 dB Rev. A | Page 4 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION BASIC CONNECTIONS Amplifier 1 (AMP1) Amplifier 2 (AMP2) Amplifier 3 (AMP3) Gain Control Amplifier 3 Matching ERROR VECTOR MAGNITUDE (EVM) PERFORMANCE THERMAL INFORMATION AND RECOMMENDED PCB LAND PATTERN FULL CHAIN OPERATION CONSIDERATIONS EVALUATION BOARD CHARACTERIZATION INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
