Datasheet ADL5246 (Analog Devices) - 5
Description3 GHz Variable Gain LNA with Integrated ½ W Driver Amplifier
Pages / Page36 / 5 — Data Sheet. ADL5246. 3.3 V. 5 V. Parameter. Test Conditions/Comments. …
Data Sheet. ADL5246. 3.3 V. 5 V. Parameter. Test Conditions/Comments. Min. Typ. Max. Min Typ. Max Unit
Data Sheet ADL5246 3.3 V 5 V Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
AMP2 FREQUENCY = 1.5 GHz RFIN2 to RFOUT2 at maximum gain Gain 7.5 10 dB vs. Frequency ±100 MHz ±0.6 ±0.7 dB vs. Temperature −40°C ≤ TA ≤ +105°C +2.5 to −4 +0.5 to −2 dB Gain Range HG mode 14.5 50 dB Input Return Loss −9 −10 dB Output Return Loss −12 −10 dB Input 1 dB Compression 7 8 dBm Point Input Third Order Intercept ∆f = 1 MHz, PIN = −5 dBm/tone 18.5 19.5 dBm Noise Figure 4.2 3.2 dB AMP2 FREQUENCY = 1.9 GHz RFIN2 to RFOUT2 at maximum gain Gain 5 7.5 dB vs. Frequency ±100 MHz ±0.6 ±0.6 dB vs. Temperature −40°C ≤ TA ≤ +105°C +2.5 to −4 +0.5 to −2 dB Gain Range HG mode 14 48 dB Input Return Loss −9 −10 dB Output Return Loss −10 −8 dB Input 1 dB Compression 9 10 dBm Point Input Third Order Intercept ∆f = 1 MHz, PIN = −5 dBm/tone 20.5 21.5 dBm Noise Figure 4.6 3.6 dB AMP2 FREQUENCY = 2.2 GHz RFIN2 to RFOUT2 at maximum gain Gain 3.5 5.5 dB vs. Frequency ±100 MHz ±0.5 ±0.5 dB vs. Temperature −40°C ≤ TA ≤ +105°C +2 to −3 +0.5 to −2 dB Gain Range HG mode 13.5 45 dB Input Return Loss −9 −10 dB Output Return Loss −8 −7 dB Input 1 dB Compression 11 11 dBm Point Input Third Order Intercept ∆f = 1 MHz, PIN = −5 dBm/tone 22.5 23 dBm Noise Figure 5.1 4.2 dB AMP2 FREQUENCY = 2.6 GHz RFIN2 to RFOUT2 at maximum gain Gain 1.5 3.7 dB vs. Frequency ±100 MHz ±0.5 ±0.5 dB vs. Temperature −40°C ≤ TA ≤ +105°C +2 to −3 +0.3 to −3 dB Gain Range HG mode 13 42 dB Input Return Loss −9 −10 dB Output Return Loss −7.5 −6.5 dB Input 1 dB Compression 14 13.5 dBm Point Input Third Order Intercept ∆f = 1 MHz, PIN = –5 dBm/tone 24 24.5 dBm Noise Figure 5.3 4.3 dB AMP2 GAIN SETTLING, 0.9 GHz RFIN2 to RFOUT2 Full Range Step, VGAIN1 or 1 dB settling, HG mode VGAIN2 0 to 3.3 V 2 1 µs 3.3 to 0 V 4 3 µs 0.5 VGAIN Step HG mode, VGAIN1 = 2.0 to 1.5 V, 1 dB 4 3 µs settling HG to LG Transition VGAIN1 = VGAIN2 = 0 V, 1 dB settling 0.3 0.2 µs LG to HG Transition VGAIN1 = VGAIN2 = 0 V, 1 dB settling 0.2 0.1 µs Rev. A | Page 5 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION BASIC CONNECTIONS Amplifier 1 (AMP1) Amplifier 2 (AMP2) Amplifier 3 (AMP3) Gain Control Amplifier 3 Matching ERROR VECTOR MAGNITUDE (EVM) PERFORMANCE THERMAL INFORMATION AND RECOMMENDED PCB LAND PATTERN FULL CHAIN OPERATION CONSIDERATIONS EVALUATION BOARD CHARACTERIZATION INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
