Datasheet ADL5246 (Analog Devices) - 6
Description3 GHz Variable Gain LNA with Integrated ½ W Driver Amplifier
Pages / Page36 / 6 — ADL5246. Data Sheet. 3.3 V. 5 V. Parameter. Test Conditions/Comments. …
ADL5246. Data Sheet. 3.3 V. 5 V. Parameter. Test Conditions/Comments. Min. Typ. Max. Min Typ. Max Unit
ADL5246 Data Sheet 3.3 V 5 V Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
AMP3 FREQUENCY = 0.75GHz RFIN3 to RFOUT3 pins Gain dB vs. Frequency ±50 MHz +0 to −1 +0 to −1.25 dB vs. Temperature −40°C ≤ TA ≤ +105°C +0.5 to −1 +0.6 to −0.9 dB vs. Supply 3.135 V to 3.465 V +0.3 to −0.3 dB 4.75 V to 5.25 V +0.05 to dB −0.1 Input Return Loss S11 −10.5 −14 dB Output Return Loss S22 −10 −12.4 dB Output 1 dB Compression 26 28.8 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 31.8 41 dBm Noise Figure 3.5 4.5 dB AMP3 FREQUENCY = 0.9 GHz RFIN3 to RFOUT3 pins Gain 16.3 16.3 dB vs. Frequency ±50 MHz +0 to −0.7 +0 to −1 dB vs. Temperature −40°C ≤ TA ≤ +105°C +0.6 to −0.8 +0.6 to −0.9 dB vs. Supply 3.135 V to 3.465 V +0.3 to −0.3 dB 4.75 V to 5.25 V +0.05 to dB −0.15 Input Return Loss S11 −11.5 −13.5 dB Output Return Loss S22 −12.5 −13.5 dB Output 1 dB Compression 25.5 29 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 33.8 41.4 dBm Noise Figure 3.3 4.3 dB AMP3 FREQUENCY = 1.9 GHz RFIN3 to RFOUT3 pins Gain 12.8 13.8 dB vs. Frequency ±100 MHz 0 to −2 0 to −1.5 dB vs. Temperature −40°C ≤ TA ≤ +105°C +0.7 to −1 +0.7 to −1 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V +0.3 to −0.2 0 to −0.2 dB Input Return Loss S11 −14 −14 dB Output Return Loss S22 −16 −18 dB Output 1 dB Compression 24.5 28.5 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 30.5 37.8 dBm Noise Figure 5.8 6.1 dB AMP3 FREQUENCY = 2.2 GHz RFIN3 to RFOUT3 pins Gain 12 12.8 dB vs. Frequency ±100 MHz 0 to −1.75 0 to −1.8 dB vs. Temperature −40°C ≤ TA ≤ +105°C +1 to −1 +1 to −1 dB vs. Supply 3.135 V to 3.465 V, 4.75 V to 5.25 V +0.4 to −0.2 0 to −0.3 dB Input Return Loss S11 −14 −15.5 dB Output Return Loss S22 −16 −18 dB Output 1 dB Compression 25 28.8 dBm Point Output Third Order Intercept ∆f = 1 MHz, POUT = 0 dBm/tone 28 37 dBm Noise Figure 5.4 5.9 dB Rev. A | Page 6 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION BASIC CONNECTIONS Amplifier 1 (AMP1) Amplifier 2 (AMP2) Amplifier 3 (AMP3) Gain Control Amplifier 3 Matching ERROR VECTOR MAGNITUDE (EVM) PERFORMANCE THERMAL INFORMATION AND RECOMMENDED PCB LAND PATTERN FULL CHAIN OPERATION CONSIDERATIONS EVALUATION BOARD CHARACTERIZATION INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
