Datasheet ADL5330 (Analog Devices) - 8
Description10 MHz to 3 GHz VGA with 60 dB Gain Control Range
Pages / Page24 / 8 — ADL5330. Data Sheet. –115. OIP3. –120. –125. INPUT P1dB. –130. (dBm/Hz). …
RevisionB
File Format / SizePDF / 695 Kb
ADL5330. Data Sheet. –115. OIP3. –120. –125. INPUT P1dB. –130. (dBm/Hz). –135. –10. R (dBm). –140. FLOOR (dBm/Hz). –20. FLOOR. OUTPUT P1dB. –145. NOIS. –30
ADL5330 Data Sheet –115 OIP3 –120 –125 INPUT P1dB –130 (dBm/Hz) –135 –10 R (dBm) –140 FLOOR (dBm/Hz) –20 FLOOR OUTPUT P1dB –145 NOIS –30
ADL5330 Data Sheet 40 –115 30 –115 OIP3 OIP3 30 –120 20 –120 20 –125 10 –125 INPUT P1dB INPUT P1dB 10 –130 0 –130 (dBm/Hz) 0 –135 –10 –135 R (dBm) R (dBm) WE WE O –10 –140 FLOOR (dBm/Hz) O –20 –140 FLOOR P E P E OUTPUT P1dB OUTPUT P1dB –20 –145 NOIS –30 –145 NOIS –30 –150 –40 –150 –40 –155 –50 –155 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 VGAIN (V)
05134-009
VGAIN (V)
05134-012 Figure 9. Input Compression Point, Output Compression Point, Figure 12. Input Compression Point, Output Compression Point, OIP3, and Noise Floor vs. VGAIN at 100 MHz OIP3, and Noise Floor vs. VGAIN at 2200 MHz
40 –115 30 –120 OIP3 OIP3 30 –120 20 –125 INPUT P1dB 20 –125 10 –130 INPUT P1dB 10 –130 0 –135 0 –135 –10 –140 R (dBm) R (dBm) WE WE OUTPUT P1dB O –10 –140 FLOOR (dBm/Hz) O –20 –145 FLOOR (dBm/Hz) P E OUTPUT P1dB P E –20 –145 NOIS –30 –150 NOIS –30 –150 –40 –155 –40 –155 –50 –160 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 VGAIN (V)
05134-010
VGAIN (V)
05134-013 Figure 10. Input Compression Point, Output Compression Point, Figure 13. Input Compression Point, Output Compression Point, OIP3, and Noise Floor vs. VGAIN at 450 MHz OIP3, and Noise Floor vs. VGAIN at 2700 MHz
40 –115 T T 30 –120 OIP3 20 –125 INPUT P1dB 10 –130 (dBm/Hz) 0 –135 R (dBm) 2 E W O –10 –140 FLOOR P E OUTPUT P1dB –20 –145 NOIS –30 –150 –40 –155 1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 CH1 200mV CH2 100mV M100ns A CH4 2.70V VGAIN (V)
05134-011
T 382.000ns
05134-014 Figure 11. Input Compression Point, Output Compression Point, Figure 14. Step Response of Gain Control Input OIP3, and Noise Floor vs. VGAIN at 900 MHz Rev. B | Page 8 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS RF INPUT/OUTPUT INTERFACE GAIN CONTROL INPUT AUTOMATIC GAIN CONTROL INTERFACING TO AN IQ MODULATOR WCDMA TRANSMIT APPLICATION CDMA2000 TRANSMIT APPLICATION SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
