Datasheet HMC742ALP5E (Analog Devices) - 5
Description0.5 dB LSB GaAs MMIC 6-Bit Digital Variable Gain Amplifier SMT, 0.07 - 4 GHz
Pages / Page12 / 5 — HMC742ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
File Format / SizePDF / 769 Kb
HMC742ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, 70 MHz - 4 GHz. 0.5 to 4.0 GHz Tuning
HMC742ALP5E 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 70 MHz - 4 GHz 0.5 to 4.0 GHz Tuning
HMC742ALP5E
v01.1213
0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 70 MHz - 4 GHz 0.5 to 4.0 GHz Tuning Relative Phase vs. Frequency Step Error vs. Frequency
30 1 T 31.5 dB 16 dB M 20 ) EG 0.5 16 dB (D 8 dB B) 0.5, 31.5 dB 10 (d R ASE O R PH 0 0 L - S ER IVE EP AT -10 ST EL ITA -0.5 R 4, 8 dB -20 IG -30 -1 0.5 1 1.5 2 2.5 3 3.5 4 0.5 1 1.5 2 2.5 3 3.5 4 FREQUENCY (GHz) FREQUENCY (GHz) S - D R IE
Noise Figure vs. Frequency [1] Output P1dB vs. Temperature
LIF 8 28 P M ) 6 B 23 d ( ) E R m U IG 4 (dB 18 IN A F E 1dB IS P A O N 2 13 0 8 LE G 0.5 1 1.5 2 2.5 3 3.5 4 0.5 1 1.5 2 2.5 3 3.5 4 B FREQUENCY (GHz) FREQUENCY (GHz) IA +25 C +85 C -40 C +25 C +85 C -40 C R A V
Psat vs. Temperature Output IP3 vs. Temperature
33 50 45 28 ) 40 ) m 23 m (dB (dB 35 at 3 s P 18 IP 30 13 25 8 20 0.5 1 1.5 2 2.5 3 3.5 4 0.5 1 1.5 2 2.5 3 3.5 4 FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -40 C +25 C +85 C -40 C [1] Max Gain State I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
