Datasheet HMC681ALP5E (Analog Devices) - 8
Description0.5 dB LSB GaAs MMIC 6-BIT Digital Variable Gain Amplifier with Serial Control, DC - 1 GHz
Pages / Page11 / 8 — HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER …
File Format / SizePDF / 825 Kb
HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz. Outline Drawing
HMC681ALP5E 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz Outline Drawing
HMC681ALP5E
v00.0113
T M L - S ITA IG S - D R IE NOTES: LIF 1. LEADFRAME MATERIAL: COPPER ALLOY P 2. DIMENSIONS ARE IN INCHES [MILLIMETERS] 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. M 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. IN A 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE A SOLDERED TO PCB RF GROUND. 7. REFER TO HITTITE APPLICATION NOTE FOR SUGGESTED LAND PATTERN. LE G B IA R
Package Information
A V Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC681ALP5E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 [1] H681A XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
