Datasheet HMC627ALP5E (Analog Devices) - 2
Description0.5 dB LSB GaAs MMIC 6-Bit Digital Variable Gain Amplifier SMT, 50 MHz - 1 GHz
Pages / Page10 / 2 — HMC627ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
File Format / SizePDF / 848 Kb
HMC627ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, 50 MHz - 1 GHz
HMC627ALP5E 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 50 MHz - 1 GHz
HMC627ALP5E
v00.1212
0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 50 MHz - 1 GHz Normalized Attenuation vs. Frequency Maximum Gain vs. Frequency [1]
(Only Major States are Shown) 25 0 ) B (d -5 20 N T IO T -10 8 dB ) [2] UA M B 15 N d E -15 ( T IN T 16 dB A A G 10 -20 D [1] E IZ L -25 A L - S 5 RM -30 31.5 dB NO ITA 0 -35 0 0.5 1 1.5 2 2.5 3 3.5 4 0 0.5 1 1.5 2 2.5 3 3.5 4 IG FREQUENCY (GHz) FREQUENCY (GHz) +25 C -40 C +85 C S - D
Input Return Loss [1] Output Return Loss [1]
R (Only Major States are Shown) (Only Major States are Shown) IE 0 0 -5 -5 LIF ) -10 ) -10 B B P (d IL (d S -15 S -15 S S M O O L -20 L -20 N N UR -25 UR T -25 T RE 31.5 dB RE -30 -30 IN A A -35 -35 -40 -40 0 0.5 1 1.5 2 2.5 3 3.5 4 0 0.5 1 1.5 2 2.5 3 3.5 4 FREQUENCY (GHz) FREQUENCY (GHz) LE G B IA
Input Return Loss [2] Output Return Loss [2]
R (Only Major States are Shown) (Only Major States are Shown) A 0 0 V -5 -5 ) -10 ) -10 B IL B (d (d S -15 S -15 S S O O L -20 L -20 N N UR -25 UR T -25 T RE 31.5 dB RE -30 -30 -35 -35 -40 -40 0 0.5 1 1.5 2 2.5 3 3.5 4 0 0.5 1 1.5 2 2.5 3 3.5 4 FREQUENCY (GHz) FREQUENCY (GHz) [1] Tested with broadband bias tee on RF ports and C1 = 10,000 pF [2] Tested with broadband bias tee on RF ports and C1 = 100 pF; L1 = 270 nF I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
