Datasheet HMC627ALP5E (Analog Devices) - 8
Description0.5 dB LSB GaAs MMIC 6-Bit Digital Variable Gain Amplifier SMT, 50 MHz - 1 GHz
Pages / Page10 / 8 — HMC627ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
File Format / SizePDF / 848 Kb
HMC627ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, 50 MHz - 1 GHz. Pin Descriptions
HMC627ALP5E 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 50 MHz - 1 GHz Pin Descriptions
HMC627ALP5E
v00.1212
Pin Number Function Description Interface Schematic This pin is DC coupled. T 1 AMPIN An off chip DC blocking capacitor is required. M RF output and DC bias (Vcc) for the output stage of the L - S 29 AMPOUT amplifier. ITA 2, 3, 13, These pins and package bottom IG GND 28, 30 - 32 must be connected to RF/DC ground. These pins are DC coupled and matched to 50 Ohms. ATTIN, S - D 12, 4 Blocking capacitors are required. Select value based ATTOUT R on lowest frequency of operation. IE External capacitors to ground is required. Select value for 5 - 10 ACG1 - ACG6 lowest frequency of operation. Place capacitor as close to LIF pins as possible. P 11 N/C No Connection M IN A A 14 SEROUT Serial input data delayed by 6 clock cycles. LE G B IA R A V 15, 16 PUP2, PUP1 D5, D4, D3, 18 - 23 D2, D1, D0 24 P/S 25 CLK 26 SERIN 27 LE 17 Vdd Supply Voltage I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
