ADL5336Data SheetABSOLUTE MAXIMUM RATINGS Table 2. Stresses at or above those listed under Absolute Maximum ParameterRating Ratings may cause permanent damage to the product. This is a Supply Voltages (VPOS, VPSD) 5.5 V stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational LE, CLK, DATA, SDO VPOS + 0.5 V section of this specification is not implied. Operation beyond ENBL, MODE VPOS + 0.5 V the maximum operating conditions for extended periods may INP1, INM1, IP2A, IM2A, IP2B, IM2B VPOS + 0.5 V affect product reliability. OPP1, OPM1, OPP2, OPM2 VPOS + 0.5 V DTO1, DTO2, GAIN1, GAIN2 VPOS/2 + 0.5 V Internal Power Dissipation 530 mW ESD CAUTION θJA (With Pad Soldered to Board) 37.4°C/W Maximum Junction Temperature 150°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C Rev. C | Page 6 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT DESCRIPTION GAIN CONTROL INTERFACE INPUT AND OUTPUT IMPEDANCES AGC OPERATION REGISTER MAP AND CODES APPLICATIONS INFORMATION BASIC CONNECTIONS SUPPLY DECOUPLING INPUT SIGNAL PATH OUTPUT SIGNAL PATH DETECTOR OUTPUT AND GAIN PIN COMMON-MODE BYPASSING SERIAL PORT CONNECTIONS MODE AND ENABLE CONNECTIONS ERROR VECTOR MAGNITUDE (EVM) EFFECT OF CAGC ON EVM AGC INSENSITIVITY TO MODULATION TYPE EFFECT OF SETPOINT ON EVM CASCADED VGA/AGC PERFORMANCE EVALUATION BOARD LAYOUT BILL OF MATERIALS (BOM) EVALUATION BOARD CONTROL SOFTWARE OUTLINE DIMENSIONS ORDERING GUIDE
