Datasheet HMC680LP4, 680LP4E (Analog Devices)
DescriptionBiCMOS 5-Bit Digital Variable Gain Amplifier SMT, 30 - 400 MHz
Pages / Page8 / 1 — HMC680LP4 / 680LP4E. BiCMOS MMIC 5-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
File Format / SizePDF / 555 Kb
HMC680LP4 / 680LP4E. BiCMOS MMIC 5-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, 30 - 400 MHz. Typical Applications. Features
Datasheet HMC680LP4, 680LP4E Analog Devices
HMC680LP4 / 680LP4E
v03.0609
BiCMOS MMIC 5-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 30 - 400 MHz Typical Applications Features
the HmC680lp4(e) is ideal for: ttl/CmOs compatible paral el or latched paral el control interface • Cel ular/3g infrastructure High Output ip3: +40 dbm (at all gain settings) • Wibro / WimaX / 4g low noise figure: 5 db • microwave radio & Vsat Wide gain Control range: 23 db • test equipment and sensors 24 lead 4x4 mm smt package: 16 mm2 • if & rf applications excel ent state & step accuracy (±0.05 db)
the HmC680lp4(e) is a digital y control ed variable gain amplifier which operates from 30 to 400 mHz, 12 and can be programmed to provide -4 db to +19 db of gain, in 1 db steps. the HmC680lp4(e) delivers noise figure of 5 db in its maximum gain state, with t output ip3 of up to +40 dbm in any state. this high m linearity dVga also provides a differential rf output s which can be used to interface directly with saW filters in tx and rx applications, and with digital to l - analog converters in rx chains. the HmC680lp4(e) is housed in a roHs compliant 4x4 mm Qfn leadless ita package, and is CmOs/ ttl compatible. ig s - d r ie
Electrical Specifications, T = +25° C, 50 Ohm System, Vdd = +5V A
parameter min. typ. max. Units lif frequency range 30 - 400 mHz p gain (maximum gain state) 17 19 db m gain Control range 23 db input return loss 12 db Output return loss 13 db in a gain accuracy: (referenced to maximum gain state) all gain states ± (0.15 + 3% of gain setting) max. db a Output power for 1db Compression 23 25 dbm Output third Order intercept point (two-tone Output power= +5 dbm each tone) [1] 40 dbm Output second Order intercept point (two-tone Output power= +5 dbm each tone) [1] 65 dbm 2nd Order 70 dbc le g Harmonics 3rd Order 75 dbc b step accuracy (referenced to maximum gain state) ±0.2 db noise figure (max gain state) 5 db ia trise, tfall (10/90% rf) 11 ns r switching Characteristics tOn, tOff (50% Ctl to 10/90% rf) 13 ns a Control supply Current idd 4 5 ma V amp supply Current (rfOUtp) 122 135 ma amp supply Current (rfOUtn) 122 135 ma [1] test frequency 50 mHz Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
12 - 1
Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
