Data SheetAD8432TYPICAL PERFORMANCE CHARACTERISTICS VS = 5 V, TA = 25°C, RS = RIN = 50 Ω, RFB =150 Ω, CSH = 47 pF, RSH = 15 Ω, RL =500 Ω (per SE output), CL = 5 pF (per SE output), G = 12.04 dB (single-ended input to differential output), f = 1 MHz, unless otherwise specified. 30242418181212)66B)dB(d0(IN0INGA–6GA–6–12–12–18G = 24.08dBRIN UNTERMINATEDG = 21.58dBR–24–18IN = 200ΩG = 18.06dBRIN = 100ΩG = 12.04dBRIN = 50Ω–30–24 3 1101001k 6 00 1101001k 05 1- 1- 34 FREQUENCY (MHz)FREQUENCY (MHz) 34 08 08 Figure 3. Small Signal Differential Gain vs. Frequency, RIN Unterminated Figure 6. Small Signal Frequency Response vs. RIN, G = 21.58 dB 243021241818151212) B9)dB6(d (IN6IN0GA3GA0–6–3–12–6RIN UNTERMINATEDRRIN UNTERMINATEDIN = 200ΩR–9R–18IN = 200ΩIN = 100ΩRIN = 100ΩRIN = 50ΩR–12IN = 50Ω–24110100500 04 7 0 1101001k 1- -05 FREQUENCY (MHz) 34 41 FREQUENCY (MHz) 08 83 0 Figure 4. Small Signal Frequency Response vs. RIN, G = 12.04 dB Figure 7. Small Signal Frequency Response vs. RIN, G = 24.08 dB 243018241218126) B)dB6(d0(ININGAA0G–6–6–12–12RIN UNTERMINATEDG = 24.08dB–18RIN = 200ΩG = 21.58dBR–18IN = 100ΩG = 18.06dBRIN = 50ΩG = 12.04dB–24–241101001k 58 55 1101001k 0 -0 1- FREQUENCY (MHz) 41 834 83 FREQUENCY (MHz) 0 0 Figure 5. Small Signal Frequency Response vs. RIN, G = 18.06 dB Figure 8. Differential Gain vs. Frequency, VOUT = 1 V p-p, RIN = 50 Ω Rev. D | Page 7 of 32 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION LOW NOISE AMPLIFIER (LNA) GAIN SETTING TECHNIQUE ACTIVE INPUT RESISTANCE MATCHING APPLICATIONS INFORMATION TYPICAL SETUP I/Q DEMODULATION FRONT END DIFFERENTIAL-TO-SINGLE-ENDED CONVERSION EVALUATION BOARD CONNECTION AND OPERATION Power Supply Input Termination Setting the Amplifier Gain Output SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES NOTES
