Datasheet BC846AW, BC846BW, BC847AW, BC847BW, BC847CW, BC848AW, BC848BW, BC848CW (Diodes) - 2
Manufacturer | Diodes |
Description | NPN |
Pages / Page | 6 / 2 — BC846AW-BC848CW. Absolute Maximum Ratings. Characteristic Symbol. Value. … |
Revision | 13-2 |
File Format / Size | PDF / 202 Kb |
BC846AW-BC848CW. Absolute Maximum Ratings. Characteristic Symbol. Value. Unit. Thermal Characteristics. ESD Ratings. JEDEC. Class
BC846AW-BC848CW Absolute Maximum Ratings
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Value Unit
BC846 80 Collector-Base Voltage BC847 VCBO V 50 BC848 30 BC846 65 Collector-Emitter Voltage BC847 VCEO V 45 BC848 30 BC846, BC847 6 Emitter-Base Voltage VEBO V BC848 5 Continuous Collector Current IC 100 mA Peak Collector Current ICM 200 mA Peak Base Current IBM 200 mA
Power Dissipation (Note 6) PD 200 mW Thermal Resistance, Junction to Ambient (Note 6) RθJA 625 °C/W Operating and Storage Temperature Range TJ, TSTG -65 to +150 °C
ESD Ratings
(Note 7)
Characteristic Symbol Value Unit JEDEC Class
Electrostatic Discharge - Human Body Model ESD HBM 4,000 V 3A Electrostatic Discharge - Machine Model ESD MM 400 V C Notes: 6. For a device mounted on minimum recommended pad layout 1oz weight copper that is on a single-sided FR4 PCB; device is measured under still air conditions whilst operating in a steady-state. 7. Refer to JEDEC specification JESD22-A114 and JESD22-A115. BC846AW – BC848CW 2 of 6 December 2013 Document Number: DS30250 Rev. 13 - 2
www.diodes.com
© Diodes Incorporated
