Datasheet MAX5527, MAX5528, MAX5529 (Maxim) - 2
ManufacturerMaxim
Description64-Tap, One-Time Programmable, Linear-Taper Digital Potentiometers
Pages / Page12 / 2 — One-Time Programmable, Linear-Taper Digital Potentiometers. ABSOLUTE …
File Format / SizePDF / 223 Kb
One-Time Programmable, Linear-Taper Digital Potentiometers. ABSOLUTE MAXIMUM RATINGS. ELECTRICAL CHARACTERISTICS. PARAMETER
One-Time Programmable, Linear-Taper Digital Potentiometers ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS PARAMETER
VDD to GND ...-0.3V to +6.0V Continuous Power Dissipation (TA = +70°C) PV to GND ...-0.3V to +12.0V 8-Pin µMAX (derate 4.5mW/°C above +70°C) ..362mW All Other Pins to GND...-0.3V to (VDD + 0.3V) 8-Pin TDFN (derate 18.2mW/°C above +70°C) ...1454.5mW Maximum Continuous Current into H, L, and W Operating Temperature Range ...-40°C to +105°C MAX5527 ..±0.5mA Junction Temperature ..+150°C MAX5528 ..±1.0mA Storage Temperature Range ...-65°C to +150°C MAX5529 ..±2.0mA Lead Temperature (soldering, 10s) ...+300°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(VDD = +2.7V to +5.5V, VH = VDD, VL = GND, TA = -40°C to +105°C, unless otherwise noted. Typical values are at VDD = +5.0V, TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS DC PERFORMANCE
Resolution 64 Taps MAX5527 75 100 125 End-to-End Resistance MAX5528 37.5 50 62.5 kΩ MAX5529 7.5 10 12.5 End-to-End Resistance TCR 35 ppm/°C Temperature Coefficent Resistance Ratio Temperature MAX5527/MAX5528 5 ppm/°C
MAX5527/MAX5528/MAX5529
Coefficient MAX5529 10 Potentiometer configuration, no load, Integral Nonlinearity INL ±0.025 ±1 LSB Figure 1 Potentiometer configuration, no load, Differential Nonlinearity DNL ±0.01 ±1 LSB Figure 1 Potentiometer configuration, no load, Full-Scale Error -0.005 -1 LSB Figure 1 Potentiometer configuration, no load, Zero-Scale Error +0.006 +1 LSB Figure 1 VDD ≥ 3V 90 200 Wiper Resistance (Note 2) RW Ω VDD < 3V 125 650
DYNAMIC CHARACTERISTICS
MAX5527 100 Wiper -3dB Bandwidth (Note 3) MAX5528 200 kHz MAX5529 1000 MAX5527 -78 f = 10kHz, midscale, 1V Total Harmonic Distortion RMS MAX5528 -82 dB RL = 100kΩ MAX5529 -94
2 _______________________________________________________________________________________
