Datasheet CA139, CA139A, CA239, CA339, LM339, LM2901, LM3302 (Intersil) - 5
Manufacturer | Intersil |
Description | Quad Voltage Comparators for Industrial, Commercial and Military Applications |
Pages / Page | 6 / 5 — CA139, CA139A, CA239, CA339, LM339, LM2901, LM3302. Typical Performance … |
File Format / Size | PDF / 67 Kb |
CA139, CA139A, CA239, CA339, LM339, LM2901, LM3302. Typical Performance Curves. 100. TA = 25oC. A = 25oC. GE (mV). -50. V+ = +5V. -100
CA139, CA139A, CA239, CA339, LM339, LM2901, LM3302 Typical Performance Curves 100 TA = 25oC T 0 A = 25oC 50 GE (mV) -50 GE (mV) V+ = +5V A 0 A T T L V+ = +5V L -100 O O V 3 I 5.1k
Ω
V 3 I 5.1k
Ω
4 - INPUT V INPUT V 2 4 - 5 + 2 VO VO 5 + 5 12 5 12 4 GE (V) GE (V) 4 A A T 3 100mV T 20mV L L 3 O INPUT O 2 INPUT OVERDRIVE 2 20mV OVERDRIVE = 5mV 100mV 1 = 5mV 1 OUTPUT V 0 OUTPUT V 0 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 2.0 TIME (
µ
s) TIME (
µ
s) FIGURE 3. RESPONSE TIME FOR VARIOUS INPUT FIGURE 4. RESPONSE TIME FOR VARIOUS INPUT OVERDRIVES - NEGATIVE TRANSITION OVERDRIVES - POSITIVE TRANSITION 101 TA = 25oC OUT OF SATURATION GE (V) A 100 T L O TION V 10-1 TURA 10-2 OUTPUT SA 10-3 10-2 10-1 100 101 102 OUTPUT SINK CURRENT (mA) FIGURE 5. OUTPUT SATURATION VOLTAGE vs OUTPUT SINK CURRENT Metallization Mask Layout 0 10 20 30 40 50 55 54 50 40
NOTE: Dimensions in parentheses
30
are in mm and are derived from the
51 -5 9 (1.295 - 1.499)
basic in. dimensions as indicated. Grid graduations are in mils (10-3 inch).
20 10 0 4 - 10 (0.102 - 0.254) 52 - 60 (1.321 - 1.524)
5
