Datasheet ADA4558 (Analog Devices) - 3
DescriptionBridge Sensor Signal Conditioner IC with LIN Interface, Nonlinearity Correction, Temperature Compensation
Pages / Page12 / 3 — Data Sheet. ADA4558. SPECIFICATIONS. Table 1. Parameter. Symbol. Test …
File Format / SizePDF / 387 Kb
Data Sheet. ADA4558. SPECIFICATIONS. Table 1. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADA4558 SPECIFICATIONS Table 1 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
Supply voltage (VDD12) = 12 V, common-mode voltage (VCM) = 2 V, and TA = 25°C, unless otherwise specified. Minimum and maximum values are specified over the full supply voltage and a temperature range of −40°C to +150°C.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
POWER SUPPLY (SYSTEM) Supply Voltage VDD12 6 12 18 V Operating Range1 VDD12, LOAD DUMP Load dump for 0.3 sec 27 V VDD12, JUMP START Jump start for 60 sec 26 V Undervoltage Lockout (UVLO) VUVLO Rising 5.1 V Hysteresis 0.2 V Supply Current ISY Normal operation, VREG current (IVREG), LIN 5.0 7 mA current (ILIN) = 0 mA, TA = −40°C to +85°C Normal operation, IVREG, ILIN = 0 mA, TA = 8.2 mA −40°C to +150°C Sleep Mode Current Enabled with inactivity on the LIN bus 150 µA VREG Output VREG 3.8 4.0 4.2 V VREG Temperature Coefficient2 95 ppm/°C DVDD Regulated Voltage DVDD 1.6 1.8 2.0 V SYSTEM SPECIFICATIONS Ful -Scale Accuracy with Calibration Sensor characteristic dependent PGA gain = 2.94 V/V to 162.52 V/V 0.1 % FSR PGA gain = 224.72 V/V to 971.10 V/V 0.25 % FSR INPUT STAGE PGA Gain Setting 2.94 971.10 V/V Common-Mode Input Voltage Range 34 65 % VREG Bridge Resistance RBR 2 20 kΩ Input Electromagnetic Interference (EMI) Filter3 Cutoff Frequency (f−3 dB) 0.55 MHz Differential f−3 dB Common Mode 0.58 MHz Input Offset Voltage4 VOS 5 20 µV Voltage Drift TCVOS 10 nV/°C Maximum Input Capacitance VPOS/VNEG nodes 15 nF COARSE OFFSET5 Bridge Offset Cancel ation Range At PGA input ±60 mV/V Offset Trim Resolution PGA gain = 2.94 6 Bits PGA gain = 971.10 14 Bits Step Size At PGA output 31 mV COARSE GAIN Gain Setting Accuracy Gain = 2.94 to 162.52 −1.2 ±0.2 +1.2 % Gain = 224.72 to 971.10 −2.75 ±1 +2.75 % Gain Error Temperature Coefficient Gain ≤ 573.0 50 ppm/°C Gain = 722.3 64 ppm/°C Gain = 971.10 121 ppm/°C ADC PERFORMANCE Main ADC Resolution 14 Bits ADC Integral Nonlinearity (INL) −4 +4 LSB14 ADC Differential Nonlinearity (DNL) −1 +1 LSB14 Rev. 0 | Page 3 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL CONNECTION DIAGRAM EMC PERFORMANCE PCB LAYOUT GUIDELINES OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
