Datasheet ADN2892 (Analog Devices) - 2
Description3.3 V 4.25 Gb/s Limiting Amplifier
Pages / Page16 / 2 — ADN2892. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 3/2017—Rev. B to …
RevisionC
File Format / SizePDF / 458 Kb
ADN2892. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 3/2017—Rev. B to Rev. C. 7/2013—Rev. 0 to Rev. A
ADN2892 Data Sheet TABLE OF CONTENTS REVISION HISTORY 3/2017—Rev B to Rev C 7/2013—Rev 0 to Rev A
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 5 link to page 5 link to page 5 link to page 6 link to page 7 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 12 link to page 13 link to page 13
Features .. 1 Limiting Amplifier ... 10 Applications ... 1 Loss-of-Signal (LOS) Detector ... 10 General Description ... 1 Received Signal Strength Indicator (RSSI) ... 10 Functional Block Diagram .. 1 Squelch Mode ... 10 Revision History ... 2 BW_SEL (Bandwidth Selection) Mode ... 10 Specifications ... 3 LOS_INV (Lose of Signal_Invert) Mode .. 10 Absolute Maximum Ratings .. 5 Applications Information .. 11 Thermal Resistance .. 5 PCB Design Guidelines ... 11 ESD Caution .. 5 Pad Coating and Pb-Free Soldering .. 12 Pin Configuration and Function Descriptions ... 6 Outline Dimensions ... 13 Typical Performance Characteristics ... 7 Ordering Guide .. 13 Theory of Operation .. 10
REVISION HISTORY 3/2017—Rev. B to Rev. C 7/2013—Rev. 0 to Rev. A
Changes to Figure 2 .. 6 Change to Output Voltage Swing Parameter, Table 1 ... 3 Changes to Figure 18 .. 11 Changes to Figure 2 ... 6 Updated Outline Dimensions ... 13 Updated Outline Dimensions ... 13 Changes to Ordering Guide .. 13 Changes to Ordering Guide .. 13
2/2014—Rev. A to Rev. B 4/2005—Revision 0: Initial Version
Changes to Figure 2 .. 6 Rev. C | Page 2 of 16 Document Outline Features Applications General Description Functional Block Diagram Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Limiting Amplifier Input Buffer CML Output Buffer Loss-of-Signal (LOS) Detector Received Signal Strength Indicator (RSSI) Squelch Mode BW_SEL (Bandwidth Selection) Mode LOS_INV (Lose of Signal_Invert) Mode Applications Information PCB Design Guidelines Output Buffer Power Supply and Ground Planes PCB Layout Soldering Guidelines for the LFCSP Pad Coating and Pb-Free Soldering Outline Dimensions Ordering Guide
