Datasheet ADXL1005 (Analog Devices) - 8
DescriptionLow Noise, Wide Bandwidth, MEMS Accelerometer
Pages / Page14 / 8 — ADXL1005. Data Sheet. 300. REFERENCE (g. OUT (g. 250. OR OUTPUT (V). 200. …
File Format / SizePDF / 499 Kb
ADXL1005. Data Sheet. 300. REFERENCE (g. OUT (g. 250. OR OUTPUT (V). 200. ) g. 150. XOUT. ( T. RAT. 100. LTAG. STANDBY. –50. –100. TIME (µs). TIME (ms). 220. 210
ADXL1005 Data Sheet 300 REFERENCE (g OUT (g 250 OR OUTPUT (V) 200 ) g 150 XOUT ( T RAT 100 LTAG STANDBY –50 –100 TIME (µs) TIME (ms) 220 210
ADXL1005 Data Sheet 6 300 6 REFERENCE (g ) X 5 OUT (g ) 250 OR OUTPUT (V) 5 4 200 4 ) g ) 3 ( V N 150 ) ( XOUT V E IO 3 ( T 2 U RAT 100 P LTAG E T O L 2 V 1 OU CE 50 STANDBY AC 1 0 0 –1 0 –50 –2
6
–100 –1 0 5 10 15 20 25 30 35 40
02 08 0 9-
–5 0 5 10
9-
TIME (µs)
658 58 1
TIME (ms)
16 Figure 16. XOUT Output Recovery from Standby Mode to Measure Mode Figure 18. Response to Overload Condition, XOUT Delta is Difference from Midscale Voltage
) 220 210 kHz ( 215 208 ) 0V 5. kHz 206 = 210 ( Y DD 204 , V NC 205 UE NCY Q 202 E UE R Q 200 F 200 RE CK O 195 198 CK F CL O L 196 A 190 CL N R 194 TE RNAL 185 IN E 193 INT 180 190 –50 0 50 100 150
019
3.0 3.5 4.0 4.5 5.0
-020 89-
TEMPERATURE (°C)
65 1
SUPPLY VOLTAGE (V)
16589 Figure 17. Internal Clock Frequency vs. Temperature at 5.0 V Supply Voltage (VDD) Figure 19. Internal Clock Frequency vs. Supply Voltage at 25°C Rev. 0 | Page 8 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measure Mode Standby Mode BANDWIDTH APPLICATIONS INFORMATION APPLICATION CIRCUIT ON DEMAND SELF TEST RATIOMETRIC OUTPUT VOLTAGE INTERFACING ANALOG OUTPUT BELOW 10 kHz INTERFACING ANALOG OUTPUT BEYOND 10 kHz OVERRANGE MECHANICAL CONSIDERATIONS FOR MOUNTING LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
