Datasheet ADXL1004 (Analog Devices) - 6
DescriptionLow Noise, Wide Bandwidth, MEMS Accelerometer
Pages / Page14 / 6 — ADXL1004. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. )) g. UDE. E ( …
File Format / SizePDF / 446 Kb
ADXL1004. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. )) g. UDE. E ( C. TION. EN 5. EF 4. R )/. LIZE. T ( 3. (OU. PER. 100. 10k. 100k
ADXL1004 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS )) g UDE E ( C TION EN 5 EF 4 R )/ LIZE T ( 3 (OU PER 100 10k 100k
ADXL1004 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 8 40 7 35 ) )) g % 6 ( 30 UDE E ( C IT TION L EN 5 A 25 P L ER AM PU D EF 4 20 R )/ PO g F LIZE O A T ( 3 T 15 M U EN OR TP C N 2 10 (OU PER 1 5 0 0 100 1k 10k 100k
004
3.80 3.84 3.88 3.92 3.96 4.00 4.04 4.08 4.12 4.16 4.20
014
FREQUENCY (Hz)
16508-
SENSITIVITY DISTRIBUTION (mV/g )
16508- Figure 4. Frequency Response, High Frequency (>5 kHz) Vibration Response; Figure 7. Sensitivity Distribution at 25°C a Laser Vibrometer Controller Referencing the ADXL1004 Package Used for Accuracy
1000000 10000 ) DUT 1 DUT 2 /√Hzg 100000 (µ Y IT 1000 ) NS 10000 DE /√Hz L g A R 1000 T 100 SPEC ISE PSD 100 O ER N W 10 10 ISE PO O N 1 1 0.01 0.1 1 10
006
100 1k 10k 100k
005
FREQUENCY (Hz)
16508-
FREQUENCY (Hz)
16508- Figure 5. Noise Power Spectral Density (PSD) below 10 Hz vs. Frequency Figure 8. Noise PSD above 100 Hz
1.0 ) le a c Full S 0.5 of % %) ( ( Y Y T T IVI ARI T 0 SI INE SEN NL NO Y T –0.5 IVI T SI SEN –60 –40 –20 0 20 40 60 80 100 120 140
025
–1.0 0 100 200 300 400 500
009
TEMPERATURE (°C)
16508-
INPUT ACCELERATION (g )
16508- Figure 6. Sensitivity vs. Temperature Figure 9. Sensitivity Nonlinearity vs. Input Acceleration Rev. 0 | Page 6 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance Recommended Soldering Profile ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Mechanical Device Operation Operating Modes Measurement Mode Standby Mode Bandwidth Applications Information Application Circuit On Demand Self Test Ratiometric Output Voltage Interfacing Analog Output Below 10 kHz Interfacing Analog Output Beyond 10 kHz Overrange Mechanical Considerations for Mounting Layout and Design Recommendations Outline Dimensions Ordering Guide Untitled
