Datasheet ADXL1004 (Analog Devices) - 7
DescriptionLow Noise, Wide Bandwidth, MEMS Accelerometer
Pages / Page14 / 7 — Data Sheet. ADXL1004. T ( E. TION. LA U. OFFS D. LIZE. T OF P. –10. 100. …
File Format / SizePDF / 446 Kb
Data Sheet. ADXL1004. T ( E. TION. LA U. OFFS D. LIZE. T OF P. –10. 100. 120. 2.48. 2.49. 2.50. 2.51. 2.52. 2.53. TEMPERATURE (°C). OUTPUT DISTRIBUTION (V)
Data Sheet ADXL1004 T ( E TION LA U OFFS D LIZE T OF P –10 100 120 2.48 2.49 2.50 2.51 2.52 2.53 TEMPERATURE (°C) OUTPUT DISTRIBUTION (V)
Data Sheet ADXL1004 10 40 8 35 6 ) ) % g ( 30 4 T ( E TION 25 2 LA U OFFS D 0 OP 20 LIZE –2 A T OF P 15 M N –4 E OR C N R 10 E –6 P 5 –8 –10 0 40 20 0 20 40 60 80 100 120
024
2.48 2.49 2.49 2.50 2.51 2.52 2.53
017
TEMPERATURE (°C) 0g OUTPUT DISTRIBUTION (V)
16508- 16508- Figure 10. Normalized Offset vs. Temperature Figure 13. 0 g Offset Histogram at 25°C
1100 280 ) 1050 A 260 1000 T EN A) R 950 µ 240 R ( U NT 900 Y C 220 PPL 850 CURRE Y 200 E SU 800 D 750 ANDB T 180 E MO S R 700 SU 160 650 MEA 600 140 3.3 3.5 3.7 3.9 4.1 4.3 4.5 4.7 4.9 5.1 5.3
022
023
SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V)
16508- 16508- Figure 11. Measure Mode Supply Current vs. Supply Voltage Figure 14. Standby Current vs. Supply Voltage
45 40 40 35 ) ) % 35 % ( ( 30 30 TION TION A A 25 L L 25 PU PU 20 PO PO F 20 F O O T T 15 15 EN EN C C 10 10 PER PER 5 5 0 0 920 940 960 980 1000 1020 1040 1060 1080
016
212 216 220 224 228 232 236 240 244 248
015
MEASURE MODE CURRENT (µA)
16508-
STANDBY CURRENT (µA)
16508- Figure 12. Measure Mode Current Histogram at 25°C Figure 15. Standby Current Histogram at 25°C Rev. 0 | Page 7 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance Recommended Soldering Profile ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Mechanical Device Operation Operating Modes Measurement Mode Standby Mode Bandwidth Applications Information Application Circuit On Demand Self Test Ratiometric Output Voltage Interfacing Analog Output Below 10 kHz Interfacing Analog Output Beyond 10 kHz Overrange Mechanical Considerations for Mounting Layout and Design Recommendations Outline Dimensions Ordering Guide Untitled
