14 /8 — ADXL1004. Data Sheet. 2500. REFERENCE XOUT DELTA. OVERRANGE. 2000. N (. …
PDF / 446 Kb
ADXL1004. Data Sheet. 2500. REFERENCE XOUT DELTA. OVERRANGE. 2000. N (. 1500. XOUT. (V). E (V). RAT. 1000. PU T. U O. ACCE. 500. STANDBY. INP. –500. 4.0. 4.5. 5.0
ADXL1004Data Sheet6250010REFERENCE XOUT DELTA5OVERRANGE20008)4gN (15006IO3XOUT(V)E (V)RATTGE2L10004APU TLTU OVO1ACCE5002UTSTANDBY0INP00–1–2–2–5000510152025303540 026 4.04.55.05.56.06.5 008 TIME (µs)TIME (ms) 16508- 16508- Figure 16. XOUT Output Recovery from Standby Mode to Measure Mode Figure 18. Response to Overload Condition, XOUT Delta is Difference from Midscale Voltage )204200.5kHz (203200.0)0V 5.202kHz199.5=( YDD 201199.0NC, VUE200Q198.5NCYREUE199Q198.0RECK F198O197.5CK FCL LO197197.0CLRNA196E196.5RNALINT195E196.0INT194195.5–50050100150 019 3.33.84.34.85.3 020 TEMPERATURE (°C) 16508- SUPPLY VOLTAGE (V) 16508- Figure 17. Internal Clock Frequency vs. Temperature at 5.0 V Supply Voltage (VDD) Figure 19. Internal Clock Frequency vs. Supply Voltage at 25°C Rev. 0 | Page 8 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance Recommended Soldering Profile ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Mechanical Device Operation Operating Modes Measurement Mode Standby Mode Bandwidth Applications Information Application Circuit On Demand Self Test Ratiometric Output Voltage Interfacing Analog Output Below 10 kHz Interfacing Analog Output Beyond 10 kHz Overrange Mechanical Considerations for Mounting Layout and Design Recommendations Outline Dimensions Ordering Guide Untitled
