Datasheet ADXL375 (Analog Devices) - 2
Description3-Axis, ±200 g Digital MEMS Accelerometer
Pages / Page10 / 2 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/18612
File Format / SizePDF / 174 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/18612
1. SCOPE 1.1 Scope. This drawing documents the general requirements of a high performance 3-Axis, ±200 g Digital MEMS Accelerometer microcircuit, with an operating temperature range of -55°C to +105°C. 1.2 Vendor Item Drawing Administrative Control Number. The manufacturer’s PIN is the item of identification. The vendor item drawing establishes an administrative control number for identifying the item on the engineering documentation: V62/18612 - 01 X E Drawing Device type Case outline Lead finish number (See 1.2.1) (See 1.2.2) (See 1.2.3) 1.2.1 Device type(s). Device type Generic Circuit function 01 ADXL375 –EP 3-Axis, ±200 g Digital MEMS Accelerometer 1.2.2 Case outline(s). The case outlines are as specified herein. Outline letter Number of pins Package style X 14 Land Grid Array (LGA) Package 1.2.3 Lead finishes. The lead finishes are as specified below or other lead finishes as provided by the device manufacturer: Finish designator Material A Hot solder dip B Tin-lead plate C Gold plate D Palladium E Gold flash palladium F Tin-lead alloy (BGA/CGA) Z Other
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/18612
REV PAGE 2 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/18612 REV
