Datasheet ADXL375 (Analog Devices) - 3
Description3-Axis, ±200 g Digital MEMS Accelerometer
Pages / Page10 / 3 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/18612
File Format / SizePDF / 174 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/18612
1.3 Absolute maximum ratings. 1/ Acceleration, Any Axis : Unpowered ... 10000 g Powered ... 10000 g VS .. -0.3 V to 3.9 V VDD I/O .. -0.3 V to 3.9 V Digital Pins .. -0.3 V to VDD I/O + 0.3 V or 3.9 V whichever is less Output Short-Circuit Duration (Any Pin to Ground) ... Indedfinite Temperature Range: Powered ... -55°C to 105°C Storage .. -65°C to 150°C 1.4 Thermal characteristics. Thermal resistance Case outline θJA θJC Unit Case X 2/ 150 85 °C/W 2. APPLICABLE DOCUMENTS JEDEC – SOLID STATE TECHNOLOGY ASSOCIATION (JEDEC) JESD51 – Methodology for the Thermal Measurement of Component Packages (Single Semiconductor Device). (Applications for copies should be addressed to the Electronic Industries Alliance, 3103 North 10th Street, Suite 240–S, Arlington, VA 22201-2107 or online at https://www.jedec.org) 1/ Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute maximum rated conditions for extended periods may affect device reliability. 2/ Thermal impedance simulated values are based on JEDEC 2S2P thermal test board. See JEDEC JESD-51
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/18612
REV PAGE 3 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/18612 REV
