Datasheet TLP2108 (Toshiba) - 3
ManufacturerToshiba
DescriptionPhotocouplers GaAℓAs Infrared LED & Photo IC
Pages / Page18 / 3 — TLP2108. 7. Absolute. Maximum. Ratings. (Note). (Unless. otherwise. …
File Format / SizePDF / 513 Kb
TLP2108. 7. Absolute. Maximum. Ratings. (Note). (Unless. otherwise. specified,. Ta. =. 25. ). Characteristics. Symbol. Note. Rating. Unit. LED. Input. forward
TLP2108 7 Absolute Maximum Ratings (Note) (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Rating Unit LED Input forward
TLP2108 7. Absolute Maximum Ratings (Note) (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Rating Unit LED Input forward current IF (Note 1) 20 mA Input forward current derating (Ta ≥ 75 ) ∆IF/∆Ta (Note 1) -0.4 mA/ Peak transient input forward IFPT (Note 1), 1 A current (Note 2) Input reverse voltage VR (Note 1) 5 V Input power dissipation PD (Note 1) 40 mW Input power dissipation (Ta ≥ 75 ) ∆PD/∆Ta (Note 1) -0.8 mW/ derating Detector Output current (Ta ≤ 25 ) IO (Note 1) 25 / -15 mA Output current (Ta = 100 ) IO (Note 1) 5 / -5 mA Output voltage VO (Note 1) -0.5 to 20 V Supply voltage VCC -0.5 to 20 V Output power dissipation PO (Note 1) 75 mW Output power dissipation (Ta ≥ 25 ) ∆PO/∆Ta (Note 1) -0.75 mW/ derating Common Operating temperature Topr -40 to 100 Storage temperature Tstg -55 to 125 Lead soldering temperature (10 s) Tsol 260 Isolation voltage (AC, 60 s, R.H. ≤ 60 % ) BVS (Note 3) 2500 Vrms Note: Using continuously under heavy loads (e.g. the application of high temperature/current/voltage and the significant change in temperature, etc.) may cause this product to decrease in the reliability significantly even if the operating conditions (i.e. operating temperature/current/voltage, etc.) are within the absolute maximum ratings. Please design the appropriate reliability upon reviewing the Toshiba Semiconductor Reliability Handbook ("Handling Precautions"/"Derating Concept and Methods") and individual reliability data (i.e. reliability test report and estimated failure rate, etc). Note 1: Each channel Note 2: Pulse width (Pw)≤1 µs, 300 pps Note 3: This device is considered as a two-terminal device: Pins 1, 2, 3 and 4 are shorted together, and pins 5, 6, 7 and 8 are shorted together. 8. Recommended Operating Conditions (Note) Characteristics Symbol Note Min Typ. Max Unit Input on-state current IF(ON) (Note 1) 2  10 mA Input off-state voltage VF(OFF) (Note 1) 0  0.8 V Supply voltage VCC (Note 2) 4.5  20 V Operating temperature Topr -40  100 Note: The recommended operating conditions are given as a design guide necessary to obtain the intended performance of the device. Each parameter is an independent value. When creating a system design using this device, the electrical characteristics specified in this data sheet should also be considered. Note 1: Each channel Note 2: Denotes the operating range, not the recommended operating condition. ©2016-2018 3 2018-04-05 Toshiba Electronic Devices & Storage Corporation Rev.2.0
