Datasheet TLP2108 (Toshiba) - 4
Manufacturer | Toshiba |
Description | Photocouplers GaAℓAs Infrared LED & Photo IC |
Pages / Page | 18 / 4 — TLP2108. 9. Electrical. Characteristics. (Note). (Unless. otherwise. … |
File Format / Size | PDF / 513 Kb |
TLP2108. 9. Electrical. Characteristics. (Note). (Unless. otherwise. specified,. Ta. =. -40. to. 100. ,. VCC. =. 4.5. to. 20. V). Test. Characteristics. Symbol. Note
TLP2108 9. Electrical Characteristics (Note) (Unless otherwise specified, Ta = -40 to 100 , VCC = 4.5 to 20 V) Test Characteristics Symbol Note Test Condition Min Typ. Max Unit Circuit Input forward voltage VF (Note 1) IF = 10 mA, Ta = 25 1.3 1.65 1.75 V Input forward voltage ∆VF/∆Ta (Note 1) IF = 10 mA -2.0 mV/ temperature coefficient Input reverse current IR (Note 1) VR = 5 V, Ta = 25 10 µA Input capacitance Ct (Note 1) V = 0 V, f = 1 MHz , Ta = 25 45 pF Low-level output voltage VOL (Note 1) Fig. IOL = 3.5 mA, IF = 5 mA 0.2 0.6 V 12.1.1 High-level output voltage VOH (Note 1) Fig. IOH = -2.6 mA, VF = 0.8 V, 2.7 4.0 V 12.1.2 VCC = 4.5 V IOH = -2.6 mA, VF = 0.8 V, 17.4 18.1 VCC = 20 V Low-level supply current ICCL Fig. IF1 = IF2 = 5 mA, VCC = 5.5 V 6 mA 12.1.3 IF1 = IF2 = 5 mA, VCC = 20 V 6 High-level supply current ICCH Fig. VF = 0 V, VCC = 5.5 V 6 mA 12.1.4 VF = 0 V, VCC = 20 V 6 Low-level short-circuit output IOSL (Note 1), Fig. IF = 5 mA, VCC = VO = 5.5 V 15 80 mA current (Note 2) 12.1.5 IF = 5 mA, VCC = VO = 20 V 20 90 High-level short-circuit output IOSH (Note 1), Fig. VF = 0 V, VO = GND, -5 -15 mA current (Note 2) 12.1.6 VCC = 5.5 V VF = 0 V, VO = GND, -10 -20 VCC = 20 V Threshold input current (H/L) IFHL (Note 1) IO = 3.5 mA, VO < 0.6 V 0.4 1.6 mA Threshold input voltage (L/H) VFLH (Note 1) IO = -2.6 mA, VO > 2.4 V 0.8 V Input current hysteresis IHYS VCC = 5 V 0.05 mA Note: All typical values are at VCC = 5 V, Ta = 25 , unless otherwise noted Note 1: Each channel Note 2: Duration of output short circuit time should not exceed 10 ms. 10. Isolation Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Total capacitance (input to CS (Note 1) VS = 0 V, f = 1 MHz 0.8 pF output) Isolation resistance RS (Note 1) VS = 500 V, R.H. ≤ 60 % 1×1012 1×1014 Ω Isolation voltage BVS (Note 1) AC, 60 s 2500 Vrms AC, 1s, in oil 5000 DC, 60 s, in oil 5000 Vdc Note 1: This device is considered as a two-terminal device: Pins 1, 2, 3 and 4 are shorted together, and pins 5, 6, 7 and 8 are shorted together. ©2016-2018 4 2018-04-05 Toshiba Electronic Devices & Storage Corporation Rev.2.0
