Datasheet P9222-R (IDT)
Manufacturer | IDT |
Description | Wireless Power Receiver for Low Power Applications |
Pages / Page | 52 / 1 — Wireless Power Receiver for. Low Power Applications P9222-R |
Revision | 20190927 |
File Format / Size | PDF / 2.8 Mb |
Datasheet Description Features The P9222-R is an integrated single-chip wireless power receiver
IC (Rx) for up to 5W applications. The device receives an AC power
signal from a wireless power transmitter, such as the P9235A-RB
WPC Qi BPP Wireless Transmitter IC, and converts it to a rectified
output voltage, which can be used to power devices or supply the
battery charger input in a wide range of wireless power
applications. The receiver (Rx) integrates a high-efficiency
synchronous full bridge rectifier (SFBR) and control circuits used to
send message packets to the transmitter (Tx) in order to optimize
power delivery. Ultra-compact, efficient wireless power receiver for up to 5W applications WPC 1.2.4 Qi Baseline Power Profile (BPP) compatible
Optimized light load efficiency for low power applications
Ping detection for reduced power consumption at end of
The P9222-R is highly efficient at light loads and very well-suited
for low-power applications such as earbuds case charging. A
unique Ping detect feature gives the user an early indication of the
wireless charger connection and improves thermal performance at
the end of complete battery charging. Low under-voltage lockout
(UVLO) threshold allows the receiver to start up even with a weaker
digital ping strength signal from a transmitter over an extended
area.
charging
Low under-voltage lockout (UVLO) for low voltage start-up for
faster connections over an extended area
ASK and FSK modulation/demodulation for Bi-directional
Communication: Rx-to-Tx and Tx-to-Rx
Easy configuration of design parameters through I2C interface
on an external EEPROM
ADC input to measure battery voltage or system voltage
Embedded 32-bit ARM® Cortex®-M0 processor
Internal over-voltage clamping
Low standby and operating mode power consumption
High performance low dropout (LDO) regulator with low
RDS(on) and programmable current limiting
Supports I2C slave/master mode
40-WLCSP: 5 8 ball array, 2.28 3.38 mm, 0.4mm pitch The device includes over-temperature and under/over-voltage
protection. The internal over-voltage clamping protects the rectifier
output from rising above the overvoltage level when the receiver is
quickly moved from a low-coupling position to a high-coupling
position. The integrated 32-bit ARM® Cortex®-M0 processor
(trademark of ARM, Ltd.) offers a high level of programmability and
design parameters that can be easily configured through the I2C
interface or an external EEPROM. The P9222-R is available in a RoHS ultra-small WLCSP-40
package and it is rated for a 0 to 85°C ambient operating
temperature range. Figure 1.
Block Diagram
Simplified Block Diagram
PDETB
PDET_RC VOUT DC Output CMA Typical Applications CM1 Wireless power solutions for mobile solutions including:
Wireless earbuds case charging
Wearables and fitness trackers
Mobile devices
Hearing aids case charging BST1 CS Rx
Coil OD0
OD1
OD2 AC1
CD /EN P9222-R
AC2
BST2
CM2
CMB
VRECT SCL
SDA EEPROM or AP
(Optional) ADC_IN
/Enable /INT GP0 External Thermistor GP1 ADC_IN GP2
LDO5P0
LDO1P8 Connect to LDO1P8
for External EEPROM
LDO5P0 LDO1P8 PGND © 2019 Integrated Device Technology, Inc. 1 September 27, 2019
