Datasheet TSSP960 (Vishay) - 9
ManufacturerVishay
DescriptionIR Sensor Module for Reflective Sensor, Light Barrier, and Fast Proximity Applications
Pages / Page11 / 9 — TSSP960.. VISHAY SEMICONDUCTOR GmbH STANDARD BAR CODE PRODUCT LABEL. …
File Format / SizePDF / 324 Kb
TSSP960.. VISHAY SEMICONDUCTOR GmbH STANDARD BAR CODE PRODUCT LABEL. PLAIN WRITING. ABBREVIATION. LENGTH. LONG BAR CODE TOP. TYPE
TSSP960. VISHAY SEMICONDUCTOR GmbH STANDARD BAR CODE PRODUCT LABEL PLAIN WRITING ABBREVIATION LENGTH LONG BAR CODE TOP TYPE
TSSP960..
(finished goods)
Item-description - 18 Item-number INO 8 Selection-code SEL 3 LOT-/serial-number BATCH 10 Data-code COD 3 (YWW) Plant-code PTC 2 Quantity QTY 8 Accepted by ACC - Packed by PCK - Mixed code indicator MIXED CODE - Origin xxxxxxx+ Company logo
LONG BAR CODE TOP TYPE LENGTH
Item-number N 8 Plant-code N 2 Sequence-number X 3 Quantity N 8 Total length - 21
SHORT BAR CODE BOTTOM TYPE LENGTH
Selection-code X 3 Data-code N 3 Batch-number X 10 Filter - 1 Total length - 17
DRY PACKING
In case of moisture absorption, the devices will recover to The reel is packed in an anti-humidity bag to protect the the former condition by drying under the following condition: devices from absorbing moisture during transportation and 192 h at 40 °C + 5 °C / - 0 °C and < 5 % RH (dry air / storage. nitrogen) or 96 h at 60 °C + 5 °C and < 5 % RH for all device containers Aluminum bag or 24 h at 125 °C + 5 °C not suitable for reel or tubes. Label An EIA JEDEC® standard J-STD-020 level 4 label is included on all dry bags.
LEVEL CAUTION
Reel This bag contains
4 MOISTURE-SENSITIVE DEVICES
15973 1. Shelf life in sealed bag: 12 months at < 40 °C and < 90 % relative humidity (RH)
FINAL PACKING
2. After this bag is opened, devices that will be subjected to soldering reflow or equivalent processing (peak package body temp. 260 °C) The sealed reel is packed into a cardboard box. must be 2a. Mounted within 72 hours at factory condition of < 30 °C/60 % RH or 2b. Stored at < 5 % RH
RECOMMENDED METHOD OF STORAGE
3. Devices require baking befor mounting if: Humidity Indicator Card is > 10 % when read at 23 °C ± 5 °C or Dry box storage is recommended as soon as the aluminum 2a. or 2b. are not met. bag has been opened to prevent moisture absorption. The 4. If baking is required, devices may be baked for: 192 hours at 40 °C + 5 °C/- 0 °C and < 5 % RH (dry air/nitrogen) or following conditions should be observed, if dry boxes are 96 hours at 60 °C ± 5 °C and < 5 % RH for all device containers or not available: 24 hours at 125 °C ± 5 °C not suitable for reels or tubes Bag Seal Date: • Storage temperature 10 °C to 30 °C (If blank, see barcode label) • Storage humidity ≤ 60 % RH max.
Note: Level and body temperature defined by EIA JEDEC Standard J-STD-020
After more than 72 h under these conditions moisture 22522 content will be too high for reflow soldering. EIA JEDEC standard J-STD-020 level 4 label is included on all dry bags Rev. 1.1, 17-Apr-2019
9
Document Number: 82868 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
